Marlin 2.0.x bugfix on Wanhao D6 Compile Error
Posted by JabroNole
October 22, 2019 10:06AM
I have downloaded the 2.0.x version for the wanhao d6 for marlin 2.0.x bugfix and am receiving compile errors when using the example configuration.h and configuration.adv.h. The compile errors I'm getting are SanityCheck.h: error: #error "Please select no more than one LCD controller option." I have gone through the configuration file and have confirmed that there is only 1 LCD controller option uncommented. Any help would be appreciated.
Re: Marlin 2.0.x bugfix on Wanhao D6 Compile Error
October 22, 2019 07:50PM
EDIT, ok I see it does this on the official marlin. with the provided D6 configuration files.
Edited 1 time(s). Last edit at 10/22/2019 08:02PM by Dust.
October 22, 2019 08:06PM
It does have #define U8GLIB_SSD1306 is set in configuration.h
And it has ULTIPANEL
And removing either one stops the error... still looking
In Marlin/src/inc/Conditionals_LCD.h
At line 173 I changed from:
#if ENABLED(IS_U8GLIB_SSD1306)
#endif
to:
#if ENABLED(U8GLIB_SSD1306)
#define IS_U8GLIB_SSD1306
#endif
It now compiles, but I cant test it, I don't have this hardware.
Edited 4 time(s). Last edit at 10/22/2019 09:27PM by Dust.
October 23, 2019 04:42PM
The config for 1.1.9 has both
line 1557
#define ULTIPANEL
and
line 1728
#define LCD_WIDTH 22
#define LCD_HEIGHT 5
#define LCD_RESET_PIN 5
and it compiles.
I'll try and see if your fix works. Thanks.
