Printer gets up to temp, but won’t start printing.. October 31, 2019 01:48PM |
The progress should be updated Now: M117 O.33% Est 0:09:26Since I am accessing Marlin through USB serial port, the ip changes shouldn’t matter, Just providing that info as the only thing that’s changed.
Re: Printer gets up to temp, but won’t start printing.. November 02, 2019 05:28PM |
Re: Printer gets up to temp, but won’t start printing.. November 02, 2019 10:08PM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Printer gets up to temp, but won’t start printing.. November 03, 2019 11:56AM |
Dust
1) the thermistor has detached from the hot end. even a tiny air gap will cause big issues
2) loss of power, check the hotend is attached to your controller properly. (no lose screw terminals)
3) a cooling fan blowing on the hot end when it shouldn't, not allowing it to get to temperature. (Fans should be on heatsinks or printed parts, not the not end)
4) after checking all the above, retune your hot end pid values.
Re: Printer gets up to temp, but won’t start printing.. November 03, 2019 12:02PM |
>>> m303 s245 SENDING:M303 S245 PID Autotune start bias: 205 d: 49 min: 237.19 max: 245.42 bias: 219 d: 35 min: 237.58 max: 245.10 bias: 224 d: 30 min: 237.19 max: 245.00 Ku: 9.78 Tu: 11.96 Classic PID Kp: 5.87 Ki: 0.98 Kd: 8.77 bias: 228 d: 26 min: 237.73 max: 247.19 Ku: 7.00 Tu: 11.80 Classic PID Kp: 4.20 Ki: 0.71 Kd: 6.20 bias: 228 d: 26 min: 240.63 max: 248.54 Ku: 8.36 Tu: 10.32 Classic PID Kp: 5.02 Ki: 0.97 Kd: 6.47 PID Autotune finished! Put the last Kp, Ki and Kd constants from below into Configuration.h #define DEFAULT_Kp 5.02 #define DEFAULT_Ki 0.97 #define DEFAULT_Kd 6.47 echo:Unknown command: "M1M105"
Re: Printer gets up to temp, but won’t start printing.. November 03, 2019 12:49PM |
>>> M301 P18.11 I1.86 D44.13t SENDING:M301 P18.11 I1.86 D44.13 echo: p:18.11 i:1.86 d:44.13 >>> M500 SENDING:M500 Error:EEPROM disabled [ERROR] Error:EEPROM disabled Setting hotend temperature to 245.000000 degrees Celsius. Error:Heating failed, system stopped! Heater_ID: 0 [ERROR] Error:Heating failed, system stopped! Heater_ID: 0 Errorrinter halted. kill() called! [ERROR] Errorrinter halted. kill() called!Apparently there is still an issue, but not sure what to think. I checked the power on the p/s and it is 24v as it should be.
Re: Printer gets up to temp, but won’t start printing.. November 03, 2019 03:52PM |
