Hi all
Setup
Re-Arm-Ramps 1.4
Marlin 2.0.5.3
CoreXY
Hot End- Bigtreetech 2 in 1
#define TOOLCHANGE_ZRAISE 1 // (mm) - "
does not lift 1 until tool change starts"
//#define TOOLCHANGE_NO_RETURN // Never return to the previous position on tool-change
//#define EVENT_GCODE_AFTER_TOOLCHANGE "G12X" // G-code to run after tool-change is complete
#define TOOLCHANGE_FILAMENT_SWAP
#define TOOLCHANGE_FIL_SWAP_LENGTH 50 // (mm)
#define TOOLCHANGE_FIL_EXTRA_PRIME 0 // (mm)
#define TOOLCHANGE_FIL_SWAP_RETRACT_SPEED 1800 // (mm/m)
#define TOOLCHANGE_FIL_SWAP_PRIME_SPEED 1800 // (mm/m)
//#define TOOLCHANGE_PARK
The problem I am having is the hotend pauses over the print until the tool change filament starts and leaves a pile of plastic.
Is there a way to have it do a retract 5mm lift 2mm then start the filament change.
Configuration_adv.h
Configuration.h
Edited 2 time(s). Last edit at 07/24/2020 09:37PM by oldtimmer.
