Auto Bed Leveling - Error: Probing Failed - Marlin 2.0.5.1 March 26, 2020 01:20PM |
#define Z_MIN_PROBE_PIN 19 #define Z_PROBE_SERVO_NR 0 #define Z_SERVO_ANGLES { 100, 0 } #define NOZZLE_TO_PROBE_OFFSET { -2, -26, 32.50 } #define MIN_PROBE_EDGE 10 #define XY_PROBE_SPEED 8000 #define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z #define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2) #define MULTIPLE_PROBING 3 #define Z_CLEARANCE_DEPLOY_PROBE 37 #define Z_CLEARANCE_BETWEEN_PROBES 3 #define Z_CLEARANCE_MULTI_PROBE 3 //#define Z_AFTER_PROBING 5 #define Z_PROBE_LOW_POINT -3 #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #define PROBING_HEATERS_OFF #define PROBING_FANS_OFF
>>> M111 S255 SENDING:M111 S255 echo: DEBUG:ECHO,INFO,ERRORS,DRYRUN,COMMUNICATION,LEVELING >>> G29 SENDING:G29 echo:G29 current_position= X0.00 Y0.00 Z0.00 : >>> G29 Machine Type: Cartesian Probe: SERVO PROBE Probe Offset X-2.00 Y-26.00 Z32.50 (Left-Front & Above Nozzle) Auto Bed Leveling: BILINEAR (disabled) current_position= X0.00 Y0.00 Z0.00 : Probe::set_deployed deploy: 1 Probe::move_z(37.00) >>> do_blocking_move_to X0.00 Y0.00 Z37.00 <<< do_blocking_move_to echo:busy: processing echo:busy: processing echo:busy: processing echo:busy: processing >>> do_blocking_move_to X0.00 Y0.00 Z37.00 <<< do_blocking_move_to reset_bed_level >>> Probe::probe_at_point(10.00, 10.00, raise, 0, probe_relative) current_position= X0.00 Y0.00 Z37.00 : >>> do_blocking_move_to X12.00 Y36.00 Z37.00 <<< do_blocking_move_to echo:busy: processing current_position= X12.00 Y36.00 Z37.00 : Probe::set_deployed deploy: 1 current_position= X12.00 Y36.00 Z37.00 : >>> Probe::run_z_probe current_position= X12.00 Y36.00 Z37.00 : >>> Probe::probe_down_to_z >>> do_blocking_move_to X12.00 Y36.00 Z-35.50 <<< do_blocking_move_to echo:busy: processing current_position= X12.00 Y36.00 Z32.22 : sync_plan_position current_position= X12.00 Y36.00 Z32.22 : <<< Probe::probe_down_to_z SLOW Probe fail! current_position= X12.00 Y36.00 Z32.22 : <<< run_z_probe current_position= X12.00 Y36.00 Z32.22 : Probe::set_deployed deploy: 0 Probe::move_z(37.00) >>> do_blocking_move_to X12.00 Y36.00 Z37.00 <<< do_blocking_move_to echo:busy: processing >>> do_blocking_move_to X12.00 Y36.00 Z37.00 <<< do_blocking_move_to Error: Probing Failed [ERROR] Error: Probing Failed <<< Probe::probe_at_point current_position= X12.00 Y36.00 Z37.00 : Probe::set_deployed deploy: 0 current_position= X12.00 Y36.00 Z37.00 : > probing complete <<< G29 >>> M111 S0
Re: Auto Bed Leveling - Error: Probing Failed - Marlin 2.0.5.1 April 28, 2020 10:54PM |
Re: Auto Bed Leveling - Error: Probing Failed - Marlin 2.0.5.1 July 25, 2020 12:55PM |
