nozzle probes off bed
Posted by TIQA
October 02, 2020 07:22AM
i just added piezo probe to my tronxy x5s . nozzle homes about 20mm left of bed, thats normal position. when i try to probe the bed with nozzle it tries to probe in 0,0 coordinates. tried every setting that gives some offset or distance from edge, nothing works. any ideas?
Re: nozzle probes off bed
October 02, 2020 12:58PM
Make sure that you set X_MIN_POS to a negative value. If the X home position is 20mm to the left of the bed then X_MIN_POS should be around -20 (you should measure the exact value to make sure). Once you've done this, do a "G28 X Y" (home only X and Y) followed by a "G0 X0 Y0" and ensure that the nozzle ends up just over the front-left corner of the bed. If not, adjust X_MIN_POS and Y_MIN_POS accordingly.
October 02, 2020 06:19PM
just tried that, nothing changed. still tries to probe the bed at physical 0,0. maybe it has to do something with UBL?
[pastebin.com]
[pastebin.com]
my config
Edited 1 time(s). Last edit at 10/02/2020 06:20PM by TIQA.
