No example config for SKR1.4 Turbo
Posted by acestu
November 09, 2020 03:33PM
I am building a printer with a BigTreeTech SKR1.4 turbo board, I have just gone through the debakle of Windows not being able to build the Bugfix branch of Marlin, so I am using a Mac, however in the past I have used an example config for my Anet A8 which made life easy, after checking I find that there is no example configs for BigTree boards, so my question is, I know that a lot of the functions dont need to be used but what are the important functions that you must set ?
Thanks
Stuart
Re: No example config for SKR1.4 Turbo
November 09, 2020 07:14PM
at this time there are 2 examples configs using btt skr v1.4 turbo...
config/examples/Zonestar/P802QR2/BigTreeTech SKR 1.4 Turbo (A4988)/
config/examples/Creality/Ender-5/BigTreeTech SKR 1.4 Turbo (TMC2209)/
All you "need" is
#define MOTHERBOARD BOARD_BTT_SKR_V1_4_TURBO
And set a serial port to -1 to enable usb over serial.
Everything else is optional depending on your hardware.
NB be very careful with LCD's on this board, Do not randomly try tuning the lcd connectors around 180 degrees! If you get this wrong you will kill pins on the lpc1769.
Edited 4 time(s). Last edit at 11/09/2020 08:13PM by Dust.
