yes. max temp is max temp your hardware can read.
If you could set that temp you would never exceed it. (as that is the max temp your hardware can read)
so hot end maximum temperature is always 15 below the max temp
also allows for some over shoot, which would otherwise trigger a max temp event.
bed must be 10 under.. haven't checked.
Edited 1 time(s). Last edit at 12/25/2020 07:26AM by Dust.
