Z Fade Out December 08, 2020 10:42AM |
Re: Z Fade Out December 08, 2020 07:14PM |
#define ENABLE_LEVELING_FADE_HEIGHT 3
M420 Z10
#define DEFAULT_LEVELING_FADE_HEIGHT 10.0
Re: Z Fade Out December 13, 2020 12:13PM |
Re: Z Fade Out December 13, 2020 02:04PM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Z Fade Out December 14, 2020 09:12PM |
There is no "DEFAULT_LEVELING_FADE_HEIGHT" in the current Marlin, in either configuration.h or configuration_adv.hQuote
Dust
NO!
"ENABLE_LEVELING_FADE_HEIGHT is a toggle, either true or false"
setting "#define ENABLE_LEVELING_FADE_HEIGHT 3" is garbage and is interpreted as #define ENABLE_LEVELING_FADE_HEIGHT true
M420 Z10 or DEFAULT_LEVELING_FADE_HEIGHT set the height
If you want a fade height of 3 mm set #define DEFAULT_LEVELING_FADE_HEIGHT 3
Re: Z Fade Out December 14, 2020 11:04PM |
#if ANY(MESH_BED_LEVELING, AUTO_BED_LEVELING_BILINEAR, AUTO_BED_LEVELING_UBL) // Gradually reduce leveling correction until a set height is reached, // at which point movement will be level to the machine's XY plane. // The height can be set with M420 Z #define ENABLE_LEVELING_FADE_HEIGHT #if ENABLED(ENABLE_LEVELING_FADE_HEIGHT) #define DEFAULT_LEVELING_FADE_HEIGHT 10.0 // (mm) Default fade height. #endif
Re: Z Fade Out December 21, 2020 06:49AM |
Re: Z Fade Out December 26, 2020 10:46AM |
I have just loaded the latest Marlin version (2.0.7.2)Quote
#endif
Re: Z Fade Out December 26, 2020 07:12PM |
Re: Z Fade Out December 27, 2020 06:05AM |
