You are using the wrong Configuration files.
NB If you are downloading these configuration files in a zip file from the CODE button, you first must select the branch that matches the version of Marlin you are compiling.
Branches
Release: For most Marlin users. Select the version that matches the Marlin version you are compiling.
Bugfix: For users compiling the bugfix branch of Marlin.
Import: For developers maintaining the Configuration examples.
Use the pull down menu that says import and select release-2.0.7.2, then download. Or change branch if using git.
Edited 2 time(s). Last edit at 03/29/2021 09:43PM by Dust.
