/** * Automatic Temperature Mode * * Dynamically adjust the hotend target temperature based on planned E moves. * * (Contrast with PID_EXTRUSION_SCALING, which tracks E movement and adjusts PID * behavior using an additional kC value.) * * Autotemp is calculated by (mintemp + factor * mm_per_sec), capped to maxtemp. * * Enable Autotemp Mode with M104/M109 F S B. * Disable by sending M104/M109 with no F parameter (or F0 with AUTOTEMP_PROPORTIONAL). */ #define AUTOTEMP #if ENABLED(AUTOTEMP) #define AUTOTEMP_OLDWEIGHT 0.98 // Turn on AUTOTEMP on M104/M109 by default using proportions set here //#define AUTOTEMP_PROPORTIONAL #if ENABLED(AUTOTEMP_PROPORTIONAL) #define AUTOTEMP_MIN_P 0 // (°C) Added to the target temperature #define AUTOTEMP_MAX_P 5 // (°C) Added to the target temperature #define AUTOTEMP_FACTOR_P 1 // Apply this F parameter by default (overridden by M104/M109 F) #endif #endif
Re: AUTOTEMP March 20, 2021 01:32AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: AUTOTEMP April 26, 2021 04:51PM |
Re: AUTOTEMP April 29, 2021 04:12PM |
