Hello,
My skr1.3 died and bought an skr1.4. The configuration is mostly the same but now homing is not working, it just displaces a bit on x axis then y axis and believes it is in 0,0 (i use bltouch for z axis).
I checked with M119 that triggers are working, I can manually push them and see how the status changes.
I cut the needed pin in the stepper drivers drivers as instructed for TMC2209 drivers.
I checked that sensorless homing is disabled.
All the steppers work correctly in the expected direction.
Can't find any solution on the web. And again I used almost the same configuration with my older board.
What should I test next?
