Z not moving after Marlin 2.x upgrade August 23, 2021 04:22AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 04:30AM |
Admin Registered: 16 years ago Posts: 13,886 |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 05:04AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 05:34AM |
#ifndef Z_STEP_PIN #define Z_STEP_PIN 46
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 05:52AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 06:23AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 07:04AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 08:44AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 09:32AM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 10:05AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 01:03PM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 08:42PM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 09:51PM |
Re: Z not moving after Marlin 2.x upgrade August 23, 2021 11:33PM |
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 07:00AM |
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 07:02AM |
Roberts_Clif
I would try the DEFAULT_MAX_FEEDRATE from 5 to 2 or maybe 3
#define DEFAULT_MAX_FEEDRATE { 300, 300, 2, 25 }
I noted you are using a MKS Gen controller, though selecting Ramps
#define MOTHERBOARD BOARD_RAMPS_14_EFB
Myself would select MKS related code. This allows for "EFBE" / " EFBF " just a suggestion.
This allows my 3D Printers to have control of dual variable fan for Cooling "Model / Hot-End" the other Cooling "Controller / Stepper Motor Drivers "
#define MOTHERBOARD BOARD_MKS_BASE_14
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 07:06AM |
Dust
From what I can see in the image
X stepper driver I don't recognize, perhaps there is more information on the underside of the module.
Y and E seems to be a DRV8825
Z is the external drivers via a MKS CD 57/86 stepper motor driver expansion board
So why are all stepper drivers set to tmc2208?
Can you take pictures of the external stepper drivers, any identifying marks?
Can you take images of the underside of the X stepper driver?
Do the Z stepper motors get energized. (ie become electrically locked in position, no longer free to rotate) ?
As this indicates if the enable pin is working or not
Direct link to image
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 10:33AM |
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 11:30AM |
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 01:27PM |
Re: Z not moving after Marlin 2.x upgrade August 24, 2021 10:12PM |
Re: Z not moving after Marlin 2.x upgrade August 25, 2021 03:31AM |
Re: Z not moving after Marlin 2.x upgrade August 25, 2021 04:22AM |
Re: Z not moving after Marlin 2.x upgrade August 25, 2021 10:08AM |
