How Do I Configure Pinouts For A LCD September 04, 2021 11:38AM |
if ENABLED(LCD_FOR_MELZI) define LCD_PINS_ENABLE 16 define LCD_PINS_RS 35 define LCD_PINS_D4 25 define BEEPER_PIN 27 define KILL_PIN 29 define BTN_EN1 23 define BTN_EN2 37 define BTN_ENC 17 endif
#if ENABLED(REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER) || ENABLED(LCD_FOR_MELZI) || ENABLED(SILVER_GATE_GLCD_CONTROLLER) #define DOGLCD #define U8GLIB_ST7920 #define REPRAP_DISCOUNT_SMART_CONTROLLER #endif
Re: How Do I Configure Pinouts For A LCD September 06, 2021 11:17AM |
Re: How Do I Configure Pinouts For A LCD September 06, 2021 11:44AM |
Re: How Do I Configure Pinouts For A LCD September 06, 2021 09:25PM |
Admin Registered: 13 years ago Posts: 7,000 |
5v D10 D11 D16 D17 gnd D31 D30 D29 D28
gnd D27 D23 D17 D37 5v D29 D25 D16 D35
Re: How Do I Configure Pinouts For A LCD September 08, 2021 07:45PM |
Dust
You cannot just plug this lcd into exp1 of the MKS Gen L v1
Melzi Ardentissimo pins (from your picture)
mks gen_l pins from [github.com]
Note that the 5v and gnd are switched over, you cannot correct this by flipping the plug 180.
You need to make up a custom cable.
Also note the power end of the cable is without the red stripe.
With it plugged into the MKS GEN_L like you have it, your feeding power into the wrong end of the cable.
