Move Z and Y axis at the same time with different feedrates September 03, 2021 06:53AM |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 07:19AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 07:55AM |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 08:54AM |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 08:56AM |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 10:12AM |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 10:16AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Move Z and Y axis at the same time with different feedrates September 03, 2021 11:24AM |
Dust
If you set the max feedrate of the slower axis [marlinfw.org]
eg M203 X50 Z2.5 (ie feedrate/60), and x needs to be larger or equal to F parameter or it also will limit.
then you move eg G0 X100 Z100 F3000
Z's feed rate is limited to max Z feedrate, X and also limited to max X feed rate, but since F is less or equal X max feedrate the F value is obeyed
This might work, haven't tried anything this non standard in a while...
Re: Move Z and Y axis at the same time with different feedrates September 06, 2021 03:14AM |
Dust
Re: Move Z and Y axis at the same time with different feedrates September 08, 2021 02:59AM |
Dust
Re: Move Z and Y axis at the same time with different feedrates September 09, 2021 03:45PM |
tok199hz
To better explain if I send G0 X100 Z100 F3000 both axis are moving at the same speed, which is Z_max_feedrate
