S_CURVE_ACCELERATION compilation error for STM32: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode July 25, 2022 02:34PM |
: COLLECT_GCC_OPTIONS='-o' '.pio\build\malyan_M300\src\src\module\stepper\indirection.cpp.o' '-c' '-Wno-register' '-std=gnu++14' '-std=gnu++14' '-fno-threadsafe-statics' '-fno-rtti' '-fno-exceptions' '-fno-use-cxa-atexit' '-g3' '-v' '-fmax-errors=5' '-Os' '-mcpu=cortex-m0' '-mthumb' '-ffunction-sections' '-fdata-sections' '-Wall' '-nostdlib' '--param' 'max-inline-insns-single=500' '-D' 'PLATFORMIO=60103' '-D' 'STM32F070xB' '-D' '__MARLIN_FIRMWARE__' '-D' 'NDEBUG' '-D' 'HAL_STM32' '-D' 'USBCON' '-D' 'USBD_USE_CDC' '-D' 'TIM_IRQ_PRIO=13' '-D' 'ADC_RESOLUTION=12' '-D' 'HAL_PCD_MODULE_ENABLED' '-D' 'DISABLE_GENERIC_SERIALUSB' '-D' 'HAL_UART_MODULE_ENABLED' '-D' 'BOARD_F_CPU=48000000L' '-D' 'SERIAL_RX_BUFFER_SIZE=128' '-D' 'SERIAL_TX_BUFFER_SIZE=64' '-D' 'USART_RX_BUF_SIZE=128' '-D' 'USART_TX_BUF_SIZE=64' '-D' 'STM32F0xx' '-D' 'ARDUINO=10808' '-D' 'ARDUINO_ARCH_STM32' '-D' 'ARDUINO_MALYANM300_F070CB' '-D' 'BOARD_NAME="MALYANM300_F070CB"' '-D' 'HAL_UART_MODULE_ENABLED' '-D' 'VECT_TAB_OFFSET=0x2000' '-D' 'CUSTOM_STARTUP_FILE' '-D' 'HAL_PCD_MODULE_ENABLED' '-I' 'Marlin' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\Wire\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\Servo\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\SoftwareSerial\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\EEPROM\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\SPI\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\IWatchdog\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\avr' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\LL' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\usb' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\OpenAMP' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\usb\hid' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\usb\cdc' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\STM32F0xx_HAL_Driver\Inc' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\STM32F0xx_HAL_Driver\Src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\STM32F0xx' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\ST\STM32_USB_Device_Library\Core\Inc' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\ST\STM32_USB_Device_Library\Core\Src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\open-amp\lib\include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\libmetal\lib\include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\virtual_driver' '-I' '%USERPROFILE%\.platformio\packages\framework-cmsis\CMSIS\Core\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Source\Templates\gcc' '-I' '%USERPROFILE%\.platformio\packages\framework-cmsis\CMSIS\DSP\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\variants\MALYANMx00_F070CB' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\variants\MALYANMx00_F070CB' '-mfloat-abi=soft' '-march=armv6s-m' Compiling .pio\build\malyan_M300\libd15\SPI\utility\spi_com.c.o c:/users/dietricl/.platformio/packages/toolchain-gCOLLECT_GCC_OPTIONS='-o' '.pio\build\malyan_M300\src\src\module\temperature.cpp.o' '-c' '-Wno-register' '-std=gnu++14' '-std=gnu++14' '-fno-threadsafe-statics' '-fno-rtti' '-fno-exceptions' '-fno-use-cxa-atexit' '-g3' '-v' '-fmax-errors=5' '-Os' '-mcpu=cortex-m0' '-mthumb' '-ffunction-sections' '-fdata-sections' '-Wall' '-nostdlib' '--param' 'max-inline-insns-single=500' '-D' 'PLATFORMIO=60103' '-D' 'STM32F070xB' '-D' '__MARLIN_FIRMWARE__' '-D' 'NDEBUG' '-D' 'HAL_STM32' '-D' 'USBCON' '-D' 'USBD_USE_CDC' '-D' 'TIM_IRQ_PRIO=13' '-D' 'ADC_RESOLUTION=12' '-D' 'HAL_PCD_MODULE_ENABLED' '-D' 'DISABLE_GENERIC_SERIALUSB' '-D' 'HAL_UART_MODULE_ENABLED' '-D' 'BOARD_F_CPU=48000000L' '-D' 'SERIAL_RX_BUFFER_SIZE=128' '-D' 'SERIAL_TX_BUFFER_SIZE=64' '-D' 'USART_RX_BUF_SIZE=128' '-D' 'USART_TX_BUF_SIZE=64' '-D' 'STM32F0xx' '-D' 'ARDUINO=10808' '-D' 'ARDUINO_ARCH_STM32' '-D' 'ARDUINO_MALYANM300_F070CB' '-D' 'BOARD_NAME="MALYANM300_F070CB"' '-D' 'HAL_UART_MODULE_ENABLED' '-D' 'VECT_TAB_OFFSET=0x2000' '-D' 'CUSTOM_STARTUP_FILE' '-D' 'HAL_PCD_MODULE_ENABLED' '-I' 'Marlin' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\Wire\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\Servo\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\SoftwareSerial\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\EEPROM\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\SPI\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\IWatchdog\src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\avr' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\LL' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\usb' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\OpenAMP' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\usb\hid' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino\stm32\usb\cdc' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\STM32F0xx_HAL_Driver\Inc' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\STM32F0xx_HAL_Driver\Src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\STM32F0xx' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\ST\STM32_USB_Device_Library\Core\Inc' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\ST\STM32_USB_Device_Library\Core\Src' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\open-amp\lib\include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\libmetal\lib\include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\virtual_driver' '-I' '%USERPROFILE%\.platformio\packages\framework-cmsis\CMSIS\Core\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Source\Templates\gcc' '-I' '%USERPROFILE%\.platformio\packages\framework-cmsis\CMSIS\DSP\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\variants\MALYANMx00_F070CB' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\variants\MALYANMx00_F070CB' '-mfloat-abi=soft' '-march=armv6s-m' c:/users/dietricl/.platformio/packages/toolchain-gccarmnonUFFER_SIZE=64 -D USART_RX_BUF_SIZE=128 -D USART_TX_BUF_SIZE=64 -D STM32F0xx -D ARDUINO=10808 -D ARDUINO_ARCH_STM32 -D ARDUINO_MALYANM300_F070CB -D BOARD_NAME="MALYANM300_F070CB" -D HAL_UART_MODULE_ENABLED -D VECT_TAB_OFFSET=0x2000 -D CUSTOM_STARTUP_FILE -D HAL_PCD_MODULE_ENABLED %USERPROFILE%\.platformio\packages\framework-arduinoststm32\libraries\IWatchdog\src\IWatchdog.cpp -quiet -dumpbase IWatchdog.cpp -mcpu=cortex-m0 -mthumb -mfloat-abi=soft -march=armv6s-m -auxbase-strip .pio\build\malyan_M300\libad9\IWatchdog\IWatchdog.cpp.o -g3 -Os -Wno-register -Wall -std=gnu++14 -std=gnu++14 -version -fno-threadsafe-statics -fno-rtti -fno-exceptions -fno-use-cxa-atexit -fmax-errors=5 -ffunction-sections -fdata-sections --param max-inline-insns-single=500 -o %TEMP%\ccSvE3jx.s \packages\framework-arduinoststm32\system\Middlewares\OpenAMP\open-amp\lib\include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\libmetal\lib\include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Middlewares\OpenAMP\virtual_driver' '-I' '%USERPROFILE%\.platformio\packages\framework-cmsis\CMSIS\Core\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Source\Templates\gcc' '-I' '%USERPROFILE%\.platformio\packages\framework-cmsis\CMSIS\DSP\Include' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\cores\arduino' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\variants\MALYANMx00_F070CB' '-I' '%USERPROFILE%\.platformio\packages\framework-arduinoststm32\variants\MALYANMx00_F070CB' '-mfloat-abi=soft' '-march=armv6s-m' GNU assembler version 2.33.1 (arm-none-eabi) using BFD version (xPack GNU Arm Embedded GCC, 64-bit) 2.33.1.20191025 %TEMP%\ccYSEA0P.s: Assembler messages: %TEMP%\ccYSEA0P.s:3139: Error: cannot honor width suffix -- `lsrs ip,r1,#1' %TEMP%\ccYSEA0P.s:3141: Error: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode %TEMP%\ccYSEA0P.s:3142: Error: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode %TEMP%\ccYSEA0P.s:3144: Error: selected processor does not support `smlal r1,ip,r2,r6' in Thumb mode %TEMP%\ccYSEA0P.s:3145: Error: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode %TEMP%\ccYSEA0P.s:3147: Error: selected processor does not support `smlal r1,ip,r2,r5' in Thumb mode %TEMP%\ccYSEA0P.s:3148: Error: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode %TEMP%\ccYSEA0P.s:3150: Error: selected processor does not support `smlal r1,ip,r2,r0' in Thumb mode %TEMP%\ccYSEA0P.s:3151: Error: cannot honor width suffix -- `lsrs r1,ip,#6' %TEMP%\ccYSEA0P.s:3602: Error: cannot honor width suffix -- `lsrs ip,r1,#1' %TEMP%\ccYSEA0P.s:3604: Error: selected processor does not support `umull r2,r3,r3,r6' in Thumb mode %TEMP%\ccYSEA0P.s:3605: Error: selected processor does not support `umull r2,r3,r3,r6' in Thumb mode %TEMP%\ccYSEA0P.s:3607: Error: selected processor does not support `smlal r1,ip,r2,r5' in Thumb mode %TEMP%\ccYSEA0P.s:3608: Error: selected processor does not support `umull r2,r3,r3,r6' in Thumb mode %TEMP%\ccYSEA0P.s:3610: Error: selected processor does not support `smlal r1,ip,r2,r4' in Thumb mode %TEMP%\ccYSEA0P.s:3611: Error: selected processor does not support `umull r2,r3,r3,r6' in Thumb mode %TEMP%\ccYSEA0P.s:3613: Error: selected processor does not support `smlal r1,ip,r2,r0' in Thumb mode %TEMP%\ccYSEA0P.s:3614: Error: cannot honor width suffix -- `lsrs r1,ip,#6' :
Re: S_CURVE_ACCELERATION compilation error for STM32: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode July 25, 2022 03:42PM |
Re: S_CURVE_ACCELERATION compilation error for STM32: selected processor does not support `umull r2,r3,r3,r4' in Thumb mode July 26, 2022 03:25AM |
