Hi all, thank you fir a great forum!
I am thinking of trying to swap out the control board on my raise3d pro2 plus.
I have bigtreetech sk3 with the same processor as the original board so I hope the touchscreen tablet will recognize the usb device..
But....i would like to modify the code so it provides this over usb-serial at start up...
I'm using visual code studio too if that helps any.
FIRMWARE_NAME:RAISE3D_Pro2
FIRMWARE_VERSION:0-0-66
FIRMWARE_BUILD:20181019114553
BOARD_VERSION:Raise3D_Motion_Board_V2
BOARD_SERIAL:112150102
PARAMETERS_VERSION:0-0-66
Compiled: Apr 21 2016
echo: Last Updated: Apr 21 2016 13:44:00 | Author: (none, default config)
echo: Free Memory: 3074 Bytes PlannerBufferBytes: 1232 Bytes
echo: Hardcoded Default Settings Loaded
echo: Steps per unit:
echo: M92 X80.00 Y80.00 Z800.00 E6640.00
echo: M201 Maximum Acceleration (mm/s2): X9000.00 Y9000.00 Z100.00 E10000.00
echo: M203 Maximum feedrates (mm/s): X300.00 Y300.00 Z16.00 E50.00
echo: Accelerations: P=printing, R=retract and T=travel
echo: M204 P500.00 T1000.00 R3000.00
echo: Advanced variables: S=Min feedrate (mm/s), T=maximum XY jerk (mm/s), B=minimum segment time (us), J=junction deviation, X=maximum X jerk (mm/s), Y=maximum Y jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.05 R5.00 B30000.00 J0.020 X5.00 Y5.00 Z0.50 E5.00
echo: Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo: M208 X305.00 Y305.00 Z305.00
echo: PID settings:
echo: M301 P0.035 I1.145 D0.089
echo: Support Fast Stop
echo: Filament settings: Disabled
echo: Z-Probe Offset (mm):
echo: M851 Z0.00
init finished
I'm not sure about the echos.....but I still don't quite know if it's even possible or where to start!
Any help would be most gratefully received.
Many thanks in advance for and advice....
Ian
Edited 2 time(s). Last edit at 09/10/2022 01:52PM by dorro1971.
