Hello, I've recently started constructing a custom 3d Printer driven by a Teensy 4.1 and in my initial attempts to flash marlin I have run into an issue detailed below. Any help would be greatly appreciated. Thanks in advance!
Hardware: Teensy 4.1 using BOARD_TEENSY41 default pin assignments. Wired to a RAMPS 1.4 board at 24 V using 2 extruder heaters in parallel and an openbuilds mini heated bed(eeb). Hot end thermistor is a E3D thermistor and the bed thermistor is a Little Foot GL104R5J thermistor.
Firmware: Marlin 2.1.1(CONFIGURATION_H_VERSION 02010100) flashed through arduino IDE with teensyduino extension. For more details see attached config.
Issue Description: Teensy 4.1 will not read bed temperature but can successfully read extruder temperature. When asking for temperature in Pronterface, temperature is reported as -50 with custom thermistor settings and 0 with E3D thermistor settings. When flashing identical firmware with BOARD_RAMPS_14_EEB, bed temperature can be read.
Current Debug Process:
- Measured Resistance of hot end and bed thermistors at room temp and after heating with a hair dryer. Resistances were as expected.
- Switched Little Foot Thermistor to hot end pins and E3D thermistor to bed pins, still resulted in no successful reading of bed temp and successful reading of hot end temp.
- Switched Teensy TEMP_0_PIN and TEMP_BED_PIN still resulted in no successful reading of bed temp and successful reading of hot end temp.
- Set TEMP_SENSOR_BED to 5(E3D thermistor settings) and TEMP_SENSOR_0 to 1000(custom Little Foot thermistor settings), resulting in constant reading of 0 C for bed and normal reading for hot end.
- Connected Teensy to Cura instead of Pronterface. Resulted in normal reading for hot end and constant reading of 1 C for bed
- Flashed default marlin 2.1.1 with only changes to MOTHERBOARD, TEMP_SENSOR_0, and TEMP_SENSOR_BED, still resulted in no successful reading of bed temp and successful reading of hot end temp.
- Flashed marlin 2.1.1 with bug fixes, with only changes to MOTHERBOARD, TEMP_SENSOR_0, and TEMP_SENSOR_BED, still resulted in no successful reading of bed temp and successful reading of hot end temp.
- Flashed marlin 2.1.1 "Nightly" with bug fixes, with only changes to MOTHERBOARD, TEMP_SENSOR_0, and TEMP_SENSOR_BED, still resulted in no successful reading of bed temp and successful reading of hot end temp.
- Fixed and arduino compiler warning in temperature.cpp for use of -Wimplicit-fallthrough by replacing it with Wextras
- Measured voltage at Teensy Bed Temp pin, Voltage at room temp was approximately analogous to the voltage at the Extruder temp pin.
- Enabled Pin Debugging(M43) and Pin State Control(M42), Requested full list of pins, TEMP_BED_PIN correctly assigned
- Ran PID Calibration of hot end to verify relative functionality of Marlin(M303 E0 C8 S210), Calibration ran successfully
- Flashed firmware in VS code instead of Arduino interface, no effect
- Flashed firmware with Teensyduino on mac, instead of windows, no effect
- Set TEMP_SENSOR_BED to 998( dummy 25 C constant) bed temp reported as 25 C
Attached Below are the my configuration files, a wiring reference and an image of the test setup
Edited 2 time(s). Last edit at 10/10/2022 03:03AM by Slow5586.
