SKR Mini E3 V3 and MKS Mini 12864 V3 SD card problem August 31, 2022 07:17AM |
Re: SKR Mini E3 V3 and MKS Mini 12864 V3 SD card problem August 31, 2022 11:11AM |
Re: SKR Mini E3 V3 and MKS Mini 12864 V3 SD card problem August 31, 2022 05:18PM |
Re: SKR Mini E3 V3 and MKS Mini 12864 V3 SD card problem December 09, 2022 07:42AM |
Re: SKR Mini E3 V3 and MKS Mini 12864 V3 SD card problem December 09, 2022 08:53AM |
Admin Registered: 13 years ago Posts: 7,000 |
/** * Set this option to one of the following (or the board's defaults apply): * * LCD - Use the SD drive in the external LCD controller. * ONBOARD - Use the SD drive on the control board. * CUSTOM_CABLE - Use a custom cable to access the SD (as defined in a pins file). * * :[ 'LCD', 'ONBOARD', 'CUSTOM_CABLE' ] */ //#define SDCARD_CONNECTION LCD
Re: SKR Mini E3 V3 and MKS Mini 12864 V3 SD card problem December 09, 2022 09:19AM |
