It looks like all three axis are homing but one is not retracting as much as the other two. Check your
HOMING_BUMP_MM setting. They should all be the same on a delta.
Did you run the G33 delta calibration wizard and then adjust configuration.h accordingly? I expect you'll see new values for
DELTA_ENDSTOP_ADJ. You'll need to do a
M502 followed by a
M500 to start using the new values.
DELTA_AUTO_CALIBRATION needs to be enabled in order to do this.
