Hello everyone,
I currently am using a buildtack material on the surface of my build plate, which has worked wonderfully for printing except for one issue. After the homing process my Z axis is sitting at the programmed "0" position which has started to melt the buildtack material.
If I add 5mm to Z_MIN in the "Travel limits after homing" area, will my axis raise 5mm until the extruder reaches target temp, then lower back to "0" when printing starts? I just want to raise it far enough off the surface so as not to burn my tack.
// Travel limits after homing (units are in mm)
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 205
#define Y_MAX_POS 205
#define Z_MAX_POS 205
