Reading the EEPROM settings in Marlin
Posted by bernbout
March 12, 2016 02:44AM
Hi
I have Marlin firmware and have read the M commands on the wiki on this page - [reprap.org]. I use Repetier host software to print
There are only M [500, 501, 502] commands to store settings into EEPROM and to read settings from EEPROM into the printer.
Is there any way of finding out what exactly the current EEPORM settings are?
What I would like to do is issue a command in Repetier that will read my EEPROM saved settings and display them onscreen or in some log file.
The reason I want to do this is to have like a backup of these settings to revert to in case I mess up and store some wrong setting in EEPROM.
Is there such a command?
Will M503 do this for me?
Edited 1 time(s). Last edit at 03/12/2016 02:45AM by bernbout.
Re: Reading the EEPROM settings in Marlin
March 12, 2016 03:01AM
In pronterface you see the eeprom values everytime you connect to the controller. Wonder why this is different in Repetier?
March 25, 2016 07:59PM
In Repetier-Host, under menu Config is Firmware EEPROM Configuration. This will not only display the values in EEPROM, but allow you to change them.
March 25, 2016 08:10PM
M503 will print out the currently active settings. So if you boot up, it will load values from the EEPROM, and when you give it a M503 you can see everything.
