Ok I need help here...
Posted by Freebird01
June 10, 2016 02:55PM
I have been messing with this build off and on for quite awhile now. I have a Prusa i3 steel I have built...Marlin firmware (Marlin 1.1.0-RC3) Ramps 1.4/Arduino Mega...
I for the life of me cannot get this to home...
I can jog it in each direction but when i hit the home buttons in pronterface it wont move...
i attached my configuration.h file...
hope you guys can help..
open | download - Configuration.h (40.4 KB)
Re: Ok I need help here...
June 10, 2016 03:44PM
If you're not using the MAX endstops, make sure they are disabled in configuration.h
What does M119 show? When an endstop isn't depressed, it should show open and when depressed it shows triggered.
If any show triggered when not depressed, invert them in configuration.h
June 10, 2016 04:26PM
ok... ended up using a different fork of marlin...
downloaded and flashed this one: [reprap.org]
now i have it configured where it will home ok... now i'm just figuring out all my steps/mm now
right now i have 190x190x170 in my firmware for dimensions... i know this is off but its a starting point..
question now is should my display show those values at 190x190x170 when at my home positions... (x is far left, y is all the way back, z is all the way up when homed) or should they read 0,0,0?
June 10, 2016 07:52PM
For a cartesian printer:
If you home to min endstops, it'll be 0,0,0.
Home to max endstops it will be what your bed and z size is.
June 11, 2016 06:34AM
Which is the better approach?
June 11, 2016 05:15PM
Freebird01
The one that works???
Most people home towards minimum. But Delta's have no choice but to home towards max. It is configurable so you can do what ever you need to do.
