Want to see what all this cooling fan talk is about. I changed my configuration motherboard line from 34 to 33 but now it will not compile.
error log
justpaste.it]
and this is a copy and paste of where the code breaks compiling..
justpaste.it]
Compiles fine if I go back to 34 motherboard. Any help is appreciated.
.:Edit:.
Downloaded a fresh distro of Marlin and imported all the settings one at a time. There is one command that fails to compile..
#define DISABLE_MAX_ENDSTOPS
That is needed because otherwise X Y and possibly Z(didn't test) only go in one direction and the end stops do not work.
There error log says...
DISABLE_MAX_ENDSTOPS is deprecated use 'USE_*_PLUG' command.
i can't google on 'USE_*_PLUG' and results are few to say the least. My google syntax may be lacking so if you can help that would be great.
.:Edit:.
Figured it out. Gonna post the newer firmware in case other 3D Cloner users might want to try it out after it's been tested a bit.
Edited 3 time(s). Last edit at 06/25/2016 09:15PM by darknezz19.
