rotate the axes in manual mode
Posted by a3sound
July 23, 2016 12:44PM
Hi, i have a prusa I3 pro B machine.
I try to rotate the stepper in manual mode (using the menu in the lcd..prepare-->move axis-->move 1mm) and i discover that only the extruder axis doesnt work.
The stepper is ok because i change connection of axis x to extruder axis, and it rotate..but if i reconect the stepper of extruder to his cable, nothing append.
The printer is new, and i dont know how is the problem...
Is it possible, changing firmware to change the main extruder to second one?
Thanks
Matteo
Re: rotate the axes in manual mode
July 23, 2016 03:13PM
The extruder won't turn unless your temperature is above EXTRUDE_MINTEMP which is default 170C. Otherwise you have to issue M302 to allow Cold extrusions.
July 24, 2016 05:21AM
Thanks for the answer, but i try to use that gcode and nothing change.
I think the problem is mainboard..
July 24, 2016 05:22AM
