Hi there,
I have posted this in the sanguinololu section so apologies for posting again. Just desperate to find a solution.
I just got a new sanguinololu rev 1.3a for my old Huxley printer. I am trying to upload the Marlin firmware via Arduino. I have installed the Sanguino 'board preset' in the board manager. But when I try upload the firmware it says:
pins_RAMPS.h:48: error: #error "Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu."
I tried using the Arduino Mega 'board preset' but that doesn't work either. Normally it just times out.
I have come across this online: "Since the ATmega1284 is not supported by Avrdude. You will have to burn the bootloader manually from the command line. See this file for help: ATmega1284.md."
Is that the problem that I am having since my board is a Atmega1284p, In which case I need to get some sort of programmer to redo the bootloader?
Please help! Thank you so much!
Damian
