X axis does not raise between auto leveling points August 31, 2016 01:28PM |
#define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG #define USE_ZMAX_PLUG #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #if DISABLED(ENDSTOPPULLUPS) // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN // #define ENDSTOPPULLUP_ZMIN_PROBE #endif #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define FIX_MOUNTED_PROBE #define X_PROBE_OFFSET_FROM_EXTRUDER 42 // X offset: -left +right [of the nozzle] #define Y_PROBE_OFFSET_FROM_EXTRUDER -42 // Y offset: -front +behind [the nozzle] #define Z_PROBE_OFFSET_FROM_EXTRUDER -7.04 // Z offset: -below +above [the nozzle] #define XY_PROBE_SPEED 4000 #define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z #define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2) #define PROBE_DOUBLE_TOUCH #define Z_MIN_PROBE_ENDSTOP //Uses Z_MAX PIN 32 for probe and PIN 30 for homing endstop from [reprap.org] #define Z_MIN_PROBE_PIN 32 #define Z_MIN_PROBE_REPEATABILITY_TEST //#define DISABLE_Z_MIN_PROBE_ENDSTOP #define Z_PROBE_DEPLOY_HEIGHT 15 //(-(Z_PROBE_OFFSET_FROM_EXTRUDER) + 6) // Z position for the probe to deploy/stow #define Z_PROBE_TRAVEL_HEIGHT 15 //(-(Z_PROBE_OFFSET_FROM_EXTRUDER) + 3) // Z position for travel between points #define Z_PROBE_OFFSET_RANGE_MIN -20 #define Z_PROBE_OFFSET_RANGE_MAX 20 #define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line) #define DEBUG_LEVELING_FEATURE #if ENABLED(AUTO_BED_LEVELING_FEATURE) #define AUTO_BED_LEVELING_GRID #if ENABLED(AUTO_BED_LEVELING_GRID) #define LEFT_PROBE_BED_POSITION 42 #define RIGHT_PROBE_BED_POSITION 180 #define FRONT_PROBE_BED_POSITION 70 #define BACK_PROBE_BED_POSITION 193 #define MIN_PROBE_EDGE 10 // The Z probe minimum square sides can be no smaller than this. #define AUTO_BED_LEVELING_GRID_POINTS 3 #else // !AUTO_BED_LEVELING_GRID #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // !AUTO_BED_LEVELING_GRID #define Z_PROBE_END_SCRIPT "G1 X0 Y0 F5000" #endif // AUTO_BED_LEVELING_FEATURE //#define Z_SAFE_HOMING
19:20:17.675 : G29 Auto Bed Leveling 19:20:17.679 : corrected_position=(0.00, 0.00, 0.00) : BEFORE matrix.set_to_identity 19:20:17.682 : current_position=(0.00, 0.00, 0.00) : BEFORE matrix.set_to_identity 19:20:17.684 : uncorrected_position=(0.00, 0.00, 0.00) : AFTER matrix.set_to_identity 19:20:17.688 : current_position=(0.00, 0.00, 0.00) : sync_plan_position 19:20:17.690 : current_position=(0.00, 0.00, 0.00) : setup_for_endstop_or_probe_move 19:20:17.692 : current_position=(0.00, 0.00, 0.00) : set_probe_deployed 19:20:17.693 : deploy: 1 19:20:17.693 : do_probe_raise(30.00) 19:20:17.695 : >>> do_blocking_move_to(0.00, 0.00, 30.00) 19:20:18.791 : N825 M105*40 19:20:21.891 : N826 M105*43 19:20:24.991 : N827 M105*42 19:20:27.991 : N828 M105*37 19:20:31.092 : N829 M105*36 19:20:32.752 : >>> do_blocking_move_to(0.00, 0.00, 30.00) 19:20:32.755 : >>> probe_pt(42.00, 70.00, 1) 19:20:32.757 : current_position=(0.00, 0.00, 30.00) : 19:20:32.757 : do_probe_raise(25.00) 19:20:32.759 : > do_blocking_move_to_xy(0.00, 112.00) 19:20:32.761 : >>> do_blocking_move_to(0.00, 112.00, 30.00) 19:20:34.192 : N830 M105*44 19:20:34.464 : > current_position=(0.00, 112.00, 30.00) : set_probe_deployed 19:20:34.464 : deploy: 1 19:20:34.466 : >>> do_blocking_move_to(0.00, 112.00, -195.00) 19:20:37.292 : N831 M105*45 19:20:40.392 : N832 M105*46 19:20:43.756 : current_position=(0.00, 112.00, 11.50) : sync_plan_position 19:20:43.760 : >>> do_blocking_move_to(0.00, 112.00, 13.50) 19:20:43.765 : >>> do_blocking_move_to(0.00, 112.00, 9.50) 19:20:43.769 : current_position=(0.00, 112.00, 11.50) : sync_plan_position 19:20:43.772 : current_position=(0.00, 112.00, 11.50) : run_z_probe 19:20:43.772 : > do_probe_raise 19:20:43.774 : do_probe_raise(25.00) 19:20:43.776 : >>> do_blocking_move_to(0.00, 112.00, 25.00) 19:20:43.778 : <<< probe_pt 19:20:43.780 : >>> probe_pt(111.00, 70.00, 1) 19:20:43.783 : current_position=(0.00, 112.00, 25.00) : 19:20:43.785 : do_probe_raise(25.00) 19:20:43.785 : > do_blocking_move_to_xy(69.00, 112.00) 19:20:43.787 : >>> do_blocking_move_to(69.00, 112.00, 25.00) 19:20:44.841 : > current_position=(69.00, 112.00, 25.00) : set_probe_deployed 19:20:44.844 : deploy: 1 19:20:44.846 : >>> do_blocking_move_to(69.00, 112.00, -195.00) 19:20:44.850 : current_position=(69.00, 112.00, 11.50) : sync_plan_position 19:20:44.852 : >>> do_blocking_move_to(69.00, 112.00, 13.50) 19:20:44.856 : >>> do_blocking_move_to(69.00, 112.00, 9.50) 19:20:44.863 : current_position=(69.00, 112.00, 11.50) : sync_plan_position 19:20:44.867 : current_position=(69.00, 112.00, 11.50) : run_z_probe 19:20:44.867 : > do_probe_raise 19:20:44.869 : do_probe_raise(25.00) 19:20:44.871 : >>> do_blocking_move_to(69.00, 112.00, 25.00) 19:20:44.873 : <<< probe_pt 19:20:44.873 : >>> probe_pt(180.00, 70.00, 1) 19:20:44.875 : current_position=(69.00, 112.00, 25.00) : 19:20:44.878 : do_probe_raise(25.00) 19:20:44.880 : > do_blocking_move_to_xy(138.00, 112.00) 19:20:44.882 : >>> do_blocking_move_to(138.00, 112.00, 25.00) 19:20:45.937 : > current_position=(138.00, 112.00, 25.00) : set_probe_deployed 19:20:45.939 : deploy: 1 19:20:45.939 : >>> do_blocking_move_to(138.00, 112.00, -195.00) 19:20:45.945 : current_position=(138.00, 112.00, 11.50) : sync_plan_position 19:20:45.947 : >>> do_blocking_move_to(138.00, 112.00, 13.50) 19:20:45.952 : >>> do_blocking_move_to(138.00, 112.00, 9.50) 19:20:45.958 : current_position=(138.00, 112.00, 11.50) : sync_plan_position 19:20:45.960 : current_position=(138.00, 112.00, 11.50) : run_z_probe 19:20:45.962 : > do_probe_raise 19:20:45.962 : do_probe_raise(25.00) 19:20:45.965 : >>> do_blocking_move_to(138.00, 112.00, 25.00) 19:20:45.967 : <<< probe_pt 19:20:45.969 : >>> probe_pt(180.00, 131.00, 1) 19:20:45.971 : current_position=(138.00, 112.00, 25.00) : 19:20:45.973 : do_probe_raise(25.00) 19:20:45.976 : > do_blocking_move_to_xy(138.00, 173.00) 19:20:45.976 : >>> do_blocking_move_to(138.00, 173.00, 25.00) 19:20:46.912 : > current_position=(138.00, 173.00, 25.00) : set_probe_deployed 19:20:46.912 : deploy: 1 19:20:46.917 : >>> do_blocking_move_to(138.00, 173.00, -195.00) 19:20:46.921 : current_position=(138.00, 173.00, 11.50) : sync_plan_position 19:20:46.923 : >>> do_blocking_move_to(138.00, 173.00, 13.50) 19:20:46.927 : >>> do_blocking_move_to(138.00, 173.00, 9.50) 19:20:46.934 : current_position=(138.00, 173.00, 11.50) : sync_plan_position 19:20:46.936 : current_position=(138.00, 173.00, 11.50) : run_z_probe 19:20:46.938 : > do_probe_raise 19:20:46.938 : do_probe_raise(25.00) 19:20:46.940 : >>> do_blocking_move_to(138.00, 173.00, 25.00) 19:20:46.945 : <<< probe_pt 19:20:46.945 : >>> probe_pt(111.00, 131.00, 1) 19:20:46.947 : current_position=(138.00, 173.00, 25.00) : 19:20:46.949 : do_probe_raise(25.00) 19:20:46.949 : > do_blocking_move_to_xy(69.00, 173.00) 19:20:46.951 : >>> do_blocking_move_to(69.00, 173.00, 25.00) 19:20:48.030 : > current_position=(69.00, 173.00, 25.00) : set_probe_deployed 19:20:48.030 : deploy: 1 19:20:48.034 : >>> do_blocking_move_to(69.00, 173.00, -195.00) 19:20:48.039 : current_position=(69.00, 173.00, 11.50) : sync_plan_position 19:20:48.041 : >>> do_blocking_move_to(69.00, 173.00, 13.50) 19:20:48.045 : >>> do_blocking_move_to(69.00, 173.00, 9.50) 19:20:48.052 : current_position=(69.00, 173.00, 11.50) : sync_plan_position 19:20:48.054 : current_position=(69.00, 173.00, 11.50) : run_z_probe 19:20:48.054 : > do_probe_raise 19:20:48.056 : do_probe_raise(25.00) 19:20:48.058 : >>> do_blocking_move_to(69.00, 173.00, 25.00) 19:20:48.060 : <<< probe_pt 19:20:48.062 : >>> probe_pt(42.00, 131.00, 1) 19:20:48.065 : current_position=(69.00, 173.00, 25.00) : 19:20:48.065 : do_probe_raise(25.00) 19:20:48.067 : > do_blocking_move_to_xy(0.00, 173.00) 19:20:48.069 : >>> do_blocking_move_to(0.00, 173.00, 25.00) 19:20:49.122 : > current_position=(0.00, 173.00, 25.00) : set_probe_deployed 19:20:49.122 : deploy: 1 19:20:49.124 : >>> do_blocking_move_to(0.00, 173.00, -195.00) 19:20:49.128 : current_position=(0.00, 173.00, 11.50) : sync_plan_position 19:20:49.130 : >>> do_blocking_move_to(0.00, 173.00, 13.50) 19:20:49.134 : >>> do_blocking_move_to(0.00, 173.00, 9.50) 19:20:49.140 : current_position=(0.00, 173.00, 11.50) : sync_plan_position 19:20:49.143 : current_position=(0.00, 173.00, 11.50) : run_z_probe 19:20:49.145 : > do_probe_raise 19:20:49.145 : do_probe_raise(25.00) 19:20:49.147 : >>> do_blocking_move_to(0.00, 173.00, 25.00) 19:20:49.149 : <<< probe_pt 19:20:49.151 : >>> probe_pt(42.00, 192.00, 1) 19:20:49.153 : current_position=(0.00, 173.00, 25.00) : 19:20:49.153 : do_probe_raise(25.00) 19:20:49.155 : > do_blocking_move_to_xy(0.00, 234.00) 19:20:49.157 : >>> do_blocking_move_to(0.00, 234.00, 25.00) 19:20:50.093 : > current_position=(0.00, 234.00, 25.00) : set_probe_deployed 19:20:50.093 : deploy: 1 19:20:50.095 : >>> do_blocking_move_to(0.00, 234.00, -195.00) 19:20:50.100 : current_position=(0.00, 234.00, 11.50) : sync_plan_position 19:20:50.102 : >>> do_blocking_move_to(0.00, 234.00, 13.50) 19:20:50.106 : >>> do_blocking_move_to(0.00, 234.00, 9.50) 19:20:50.113 : current_position=(0.00, 234.00, 11.50) : sync_plan_position 19:20:50.115 : current_position=(0.00, 234.00, 11.50) : run_z_probe 19:20:50.115 : > do_probe_raise 19:20:50.117 : do_probe_raise(25.00) 19:20:50.119 : >>> do_blocking_move_to(0.00, 234.00, 25.00) 19:20:50.121 : <<< probe_pt 19:20:50.121 : >>> probe_pt(111.00, 192.00, 1) 19:20:50.124 : current_position=(0.00, 234.00, 25.00) : 19:20:50.126 : do_probe_raise(25.00) 19:20:50.128 : > do_blocking_move_to_xy(69.00, 234.00) 19:20:50.130 : >>> do_blocking_move_to(69.00, 234.00, 25.00) 19:20:51.184 : > current_position=(69.00, 234.00, 25.00) : set_probe_deployed 19:20:51.184 : deploy: 1 19:20:51.188 : >>> do_blocking_move_to(69.00, 234.00, -195.00) 19:20:51.193 : current_position=(69.00, 234.00, 11.50) : sync_plan_position 19:20:51.195 : >>> do_blocking_move_to(69.00, 234.00, 13.50) 19:20:51.199 : >>> do_blocking_move_to(69.00, 234.00, 9.50) 19:20:51.205 : current_position=(69.00, 234.00, 11.50) : sync_plan_position 19:20:51.207 : current_position=(69.00, 234.00, 11.50) : run_z_probe 19:20:51.210 : > do_probe_raise 19:20:51.210 : do_probe_raise(25.00) 19:20:51.212 : >>> do_blocking_move_to(69.00, 234.00, 25.00) 19:20:51.216 : <<< probe_pt 19:20:51.216 : >>> probe_pt(180.00, 192.00, 1) 19:20:51.218 : current_position=(69.00, 234.00, 25.00) : 19:20:51.220 : do_probe_raise(25.00) 19:20:51.222 : > do_blocking_move_to_xy(138.00, 234.00) 19:20:51.224 : >>> do_blocking_move_to(138.00, 234.00, 25.00) 19:20:52.278 : > current_position=(138.00, 234.00, 25.00) : set_probe_deployed 19:20:52.278 : deploy: 1 19:20:52.283 : >>> do_blocking_move_to(138.00, 234.00, -195.00) 19:20:52.287 : current_position=(138.00, 234.00, 11.50) : sync_plan_position 19:20:52.289 : >>> do_blocking_move_to(138.00, 234.00, 13.50) 19:20:52.295 : >>> do_blocking_move_to(138.00, 234.00, 9.50) 19:20:52.299 : current_position=(138.00, 234.00, 11.50) : sync_plan_position 19:20:52.302 : current_position=(138.00, 234.00, 11.50) : run_z_probe 19:20:52.304 : > do_probe_raise
Re: X axis does not raise between auto leveling points September 13, 2016 12:50PM |
// Probe Raise options provide clearance for the probe to deploy, stow, and travel. // #define Z_PROBE_DEPLOY_HEIGHT 15 // Raise to make room for the probe to deploy / stow #define Z_PROBE_TRAVEL_HEIGHT 5 // Raise between probing points.
Re: X axis does not raise between auto leveling points January 11, 2017 06:00PM |
