Hello! I always used a sensor in the back-left from the nozzle (negative offset for X_PROBE_OFFSET_FROM_EXTRUDER and Y_PROBE_OFFSET_FROM_EXTRUDER) and all worked fine, now I change the sensor mount and it's aligned on the right of the nozzle so i set Y_PROBE_OFFSET_FROM_EXTRUDER=0 and X_PROBE_OFFSET_FROM_EXTRUDER=35 (sensor is 3.5 cm from the nozzle) and I have a problem with the origin when I print. The homing and the bed leving procedure are fine and scans at the right points, but when I start a print the origin shifts perfectly 35mm on the right so it's a little strange
, is there something to change in marlin to fix this?
Thank you
Voronix Core XY (custom model): Radds 1.6 (DRV8825) - Nextion 7" - E3d Titan + Hotend E3d V6 Direct - MK4DUO 4.3.3
