Smoke detector Kill Print?
Posted by GRAYWOLF
October 13, 2016 12:15PM
I have a smoke detector module whos output is just a switched relay NO/c/NC.
Is there a way to get marlin to stop printing and shut off all motors and heaters should the smoke detector be triggered?
I'm not sure where to ask this as it is both Marlin and Ramps 1.4 related.
Re: Smoke detector Kill Print?
October 14, 2016 09:08AM
Depending upon how the smoke detector module works, different approaches could be done. If it can handle the current, it might make sense to run all of the power for the printer through it. It would just cut power (and maybe later reset) if it detected smoke. Marlin will come up with the motors stopped and the heaters turned off.
You could also run a wire to the AVR's reset pin such that the smoke detector could reset Marlin if it detected smoke. But most likely, it would be best not to have the firmware in the loop making decisions.
