Hello
I'm working on modifying Marlin 1.1.0-RC6 to work with 2 extruders and 1 nozzle.
I have found the following code in my pins_RAMPS_24.h file.
#if MB(RAMPS_14_SF) || MB(RAMPS_13_SF) || ENABLED(IS_RAMPS_EF
#define HEATER_1_PIN -1
#else
#define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter) was pin 9
#endif
I can only find 3 places in my project where "ENABLED(IS_RAMPS_EF
" is referenced.
Once when it is defined and twice where it is check by "IF" statements.
The way I'm reading this is : IF "enabled(is_ramps_efb" has been "Enabled" then execuite
"Define HEATER_1_PIN as -1 .
This is apparently the case since I get an error message when compiling saying that heater_1_pin is not defined.
Since I've never found a place that "enables" "is_ramps_efb" it makes me wonder if I am missing something?
thank you
kd6hq
