auto bed leveling suddenly stopped working!
Posted by clearlynotstefan
November 22, 2016 08:22PM
This is a serious riddle. I use g28 then g29 before each print and have for a long time with great results, I usually manually level the bed every so often just the bottom of my prints isn't too skewed. Today I was printing without problem, did literally nothing. Jumped a step and realized my Y stepper was getting a little too much juice and rolled the pot down a bit. That's literally the only thing that changed today. I just tried to go a print, g28, g29, does the probing, echos the coefficient and matrix like normal, I jog the axis and notice my Z motors aren't compensating (no my matrix wasn't all 0s). Why on earth would g29 suddenly function, but then fail to actually apply the calculation. I didn't update firmware, change settings anything. Any ideas!?
Re: auto bed leveling suddenly stopped working!
November 22, 2016 08:41PM
Problem solved. I left out one detail, because I never set my Y stepper so high I was concerned with how it crept up and swapped it with my E2 stepper which isn't in use. Turns out the E2 stepper (formerly Y stepper) didn't get seated all the way down. Turns out if you don't have a stepper motor connected to E2 (even if you're not using it) g29 will pretend to level but not actually level!
