Just dig out your multimeter and run a continuity test over the thermistor.
More likely you have a bad joint in the pin header connector.
But min temp error typically means an open circuit on the thermistor.
Oh, you might want to turn on HEATER_BED_DUTY_CYCLE_DIVIDER.
Just to reduce the current draw on the psu.
