Auto bed level unstable December 19, 2016 02:38AM |
Re: Auto bed level unstable December 19, 2016 01:15PM |
Re: Auto bed level unstable December 19, 2016 03:26PM |
Re: Auto bed level unstable December 19, 2016 10:33PM |
Re: Auto bed level unstable December 20, 2016 10:58AM |
stephenrc
Your endstops are 'moving'.
Losing steps on the motors.
Loose screw on one or more pulleys.
For the ir sensor, bed surface not reflecting ir consistently.
Tilting of the effector.
Re: Auto bed level unstable December 25, 2016 02:41PM |
Re: Auto bed level unstable May 23, 2021 12:15PM |
Re: Auto bed level unstable May 23, 2021 05:52PM |
AngelOfGrief
This is a really old thread, but I decided to post here. Running Marlin on Prusa i3 metal frame. I too have encountered inconsistency using the bed leveling feature of Marlin. And I am using a standard inductive sensor obtained from Aliexpress and an aluminum hot bed. So, here's what I have discovered. The sensor itself is very stable, the M48 command reports something around 0.0002mm deviation. However! It is very sensitive to how clean the bed surface is! I usually use hairspray before printing. So, the thinnest layer of hairspray glue on the surface changes how the sensor reacts to metal underneath it. If you got a lot of glue residue from several uses, it gets even worse. And, although it's all non-magnetic and the sensor is supposed to "shoot" thru it, in reality it doesn''t. So whenever a particular spot of the bed is not clean enough, the sensor thinks it's closer.
Another thing... I am a long time user, I started 3d printing around 12 years ago. Now, after several messed up prints I decided to do some tuning to the printer, and I discovered that some of the Pololus are set to a pretty low current. Could have been the potentiometers moved due to vibration. Check your machines. Mine were set to around 1 volts for Y and Z, but 0.4v for X and extruder, which is pretty low. (check the pot slider with voltmeter relative to Gnd).
Also, steppers often skip if the rails are (again!) not clean and not oiled. You have to do it from time to time, at least once per year.
Hope this helps someone.
Re: Auto bed level unstable May 28, 2021 07:02AM |
