When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 26, 2017 12:49PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 26, 2017 04:48PM |
Admin Registered: 15 years ago Posts: 7,342 |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 26, 2017 07:57PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 26, 2017 09:22PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 26, 2017 10:54PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 28, 2017 03:27AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 28, 2017 08:38AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 30, 2017 11:51AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 30, 2017 11:53AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 30, 2017 12:51PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 31, 2017 03:40AM |
In file included from sketch\stepper.h:46:0,
from sketch\MarlinSerial.cpp:33:
sketch\planner.h: In static member function 'static void Planner::set_e_position_mm(const float&)':
sketch\planner.h:353:11: warning: invalid conversion from 'int' to 'AxisEnum' [-fpermissive]
+ active_extruder
+ active_extruder
In file included from sketch\temperature.h:31:0,
from sketch\Marlin_main.cpp:226:
sketch\thermistortables.h: At global scope:
sketch\thermistortables.h:677:1: warning: narrowing conversion of '3.20640015e+2' from 'double' to 'const short int' inside { } [-Wnarrowing]
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 31, 2017 03:06PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? January 31, 2017 08:30PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 01, 2017 02:47AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 01, 2017 09:30AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 02, 2017 03:27AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 02, 2017 05:23PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 07, 2017 06:33AM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 07, 2017 02:00PM |
Re: When is it necessary to setup multiple "E0 E1 E2" steps and what is the format? February 07, 2017 03:30PM |
