Nozzle position to the bed. XY
Posted by SatorCodex
March 13, 2017 04:55PM
Hi!
I have installed skynet. marlin fork.
Also installed a new bowden set up. So nozzle is not in the same position.
Z probe offset is right on the middle of the bed.
But the nozzle has moved 20mm to right in x axis( just in middle/front of the z-probe). And ca -10mm on Y axis.
I can not find where I set the nozzle position. If I change probe position (x/y) It will try to probe the bed..outside of the bed..
Have looked and looked. But can't find info about this. Im sure its easy when you know it..
Re: Nozzle position to the bed. XY
March 13, 2017 07:16PM
If you have changed the type of hot end, then i think you will need to re-position the X Y endstops so that the nozzle homes to 0,0
March 13, 2017 07:19PM
Yes.
If you mean nozzle position relative to x0 y0 ?
I can not in my life find that setting in firmware.. eye rolling smiley
