Where to start auto bed leveling Marlin
Posted by chasemn34
March 30, 2017 03:26PM
I'm running the newest Marlin firmware​ what's the quickest easy way to con fig it like what parts will I need a z probe or the new geetech 3d touch and how hard will it be what will I need to config
Re: Where to start auto bed leveling Marlin
March 31, 2017 12:03AM
3_point leveling is the easiest to get going. Just enable it and let it do its thing. It already has probe points defined. You just turn it on and it works.
March 31, 2017 08:40PM
Will I need to buy a probe and install it for the 3 point
March 31, 2017 10:13PM
For 3-Point, Yes. If you don't want to buy a probe, you can bring up UBL. There are directions how to bring it up without a probe.
March 31, 2017 11:05PM
is ubl the same as mesh bed leveling where you do it automatically or is it something different
April 01, 2017 12:42AM
It uses a high resolution mesh as its foundation. But its got a G26 Mesh Validation Pattern command that is used directly by the G29 P4 interactive mesh editor. You can get 100% adhesion across your entire print bed every time.
Edited 2 time(s). Last edit at 04/01/2017 12:43AM by Roxy.
April 01, 2017 08:13AM
Which one will be easy to config and which one will work better the actual z probe or the geetech 3d touch
