Help needed configuring for two Z steppers
Posted by rfresh737
April 09, 2017 12:36PM
I downloaded Marlin firmware version 1.1.0 RC 8 and flashed this to my laserBot laser machine which has a MegaPi controller board. The laserBot is now working fine.
I have a 3D printer frame sitting in my shop not being used which is the classic i3 Prusa type with the dual Z axis stepper motors. I am trying to convert this into a laser machine by installing a MegaPi controller board and flashing the same Marln firmware RC 8.
I uncommented the line in config adv.h
Z_DUAL_STEPPER_DRIVER
...but got a compiler error: pins.h:449: error: 'E1_STEP_PIN' was not declared in this scope.
Does anyone know how to resolve this?
My understanding is that if I can enable a second Z stepper, the 4th (and last) remaining port on the MegaPi will work the second Z stepper. I have yet to test that theory however.
Thanks...
open | download - Configuration_adv.h (51.2 KB)
open | download - Configuration.h (54.6 KB)
Re: Help needed configuring for two Z steppers
April 10, 2017 03:15AM
You might have to look in "pins.h" for your specific controller and check if the E1_.... definitions are there. If not, you can add them with the appropriate pin numbers.
Might be just a matter of renaming the pin definitions for the last stepper port.
April 10, 2017 10:54AM
Attachment shows E1_STEP_PIN is defined in pins.h ???
open | download - 2017-04-10_074649.png (53.2 KB)
April 10, 2017 11:10AM
Are you sure to really have two stepper drivers for the Z-axis, not just two stepper motors using the same driver either in parallel or in series?
If you have two Z-motors but only one stepper driver, you should not set Z_DUAL_STEPPER_DRIVER.
April 10, 2017 11:26AM
I'm using the MegaPi and it has 4 ports to connect stepper motors to.
I'm planning on connecting 4 stepper motors: X Y Z Z
Four ports/four motors.
I just have to figure out how to configure the Marlin firmware for that.
April 10, 2017 10:11PM
"Attachment shows E1_STEP_PIN is defined in pins.h ???"
no it does not, its shows defining _E1_Pin as E1_STEP_PIN
Where did you get your firmware from?
I see you have set MOTHERBOARD BOARD_MB_MEGAPI_LBOT
but BOARD_MB_MEGAPI_LBOT is not a standard supplied board. (and google isnt helping)
You need to show us the pins for this board.
If its following the new style it will be a file pins_MEGAPI_LBOT.h or something like that
If its following the old style it will have one large pins.h with everything in their.
This file needs something like, but with pins for your board.
#define E1_STEP_PIN 36
#define E1_DIR_PIN 34
#define E1_ENABLE_PIN 30
make them the same as your port 4 pins
Edited 2 time(s). Last edit at 04/10/2017 10:18PM by Dust.
April 10, 2017 11:05PM
I got the Marlin firmware from gitHub. 1.10 RC8.
MegaPi board diagram is attached.
The pin file is: pins_MB_LaserBot.h (attached also)
open | download - megapi-d-2.png (270.9 KB)
open | download - pins_MB_LaserBot.h (3.5 KB)
April 10, 2017 11:12PM
Right so
add in the following into pins_MB_LaserBot.h
#define E1_STEP_PIN 5
#define E1_DIR_PIN 4
#define E1_ENABLE_PIN 59
#define E1_CS_PIN -1
uncomment from config adv.h
(this steals E1 and re assigns it as Z2)
cross your finger and compile.
Oh you probably need to set E steps/mm same as Z
ie #define DEFAULT_AXIS_STEPS_PER_UNIT {43.74, 43.74, 760*1.1, 760*1.1}
Edited 1 time(s). Last edit at 04/10/2017 11:27PM by Dust.
April 10, 2017 11:25PM
You mean comment out, right?
April 10, 2017 11:28PM
no
make sure it is un commented, you want it enabled
ie "#define Z_DUAL_STEPPER_DRIVERS"
April 10, 2017 11:30PM
Yes I want it enabled. I had it already uncommented.
I'll give this a try.
Thank you very much for your help.
April 10, 2017 11:33PM
you should also find where your micostepping is set
M350 [reprap.org]
Make sure E is set the same as Z
April 11, 2017 03:09AM
I wonder if Marlin is able to run without any extruder driver?
enabling Z_dual_stepper_drivers, only adds a second z-driver behind the last extruder.
Can you set number of extruders to "0"?
edit: It seems, you can't set it to "0", so you might also have to change pin definitions for E0 to some unused pins and use the former E0 pins for E1 ( 2nd Z-stepper )
Edited 1 time(s). Last edit at 04/11/2017 03:17AM by o_lampe.
April 11, 2017 10:56AM
Yes Marlin can run without an Extruder. Recall I modified this RC8 to run a laser machine (the LaserBot).
April 12, 2017 02:38AM
For running a laser you sure don't have to set the #extruders to "0", because you only need X and Y.
