Enabling #define RGB_LED results in compiler error May 08, 2017 06:21AM |
sketch\Marlin_main.cpp: In function 'void gcode_M190()': Marlin_main.cpp:6890: error: expected 'while' before 'float' const float temp_diff = fabs(target_temp - temp); ^ Marlin_main.cpp:6890: error: expected '(' before 'float' Marlin_main.cpp:6890: error: expected primary-expression before 'float' Marlin_main.cpp:6890: error: expected ')' before 'float' Marlin_main.cpp:6890: error: expected ';' before 'float' Marlin_main.cpp:6890: error: 'temp' was not declared in this scope const float temp_diff = fabs(target_temp - temp); ^ Marlin_main.cpp:6908: error: break statement not within loop or switch if (old_temp - temp < MIN_COOLING_SLOPE_DEG_BED) break; ^ sketch\Marlin_main.cpp: At global scope: Marlin_main.cpp:6914: error: expected unqualified-id before 'while' } while (wait_for_heatup && TEMP_BED_CONDITIONS); ^ Marlin_main.cpp:6916: error: expected unqualified-id before 'if' if (wait_for_heatup) LCD_MESSAGEPGM(MSG_BED_DONE); ^ In file included from sketch\Marlin.h:32:0, from sketch\Marlin_main.cpp:223: ultralcd.h:64: error: expected unqualified-id before ')' token #define LCD_MESSAGEPGM(x) lcd_setstatuspgm(PSTR(x)) ^ sketch\Marlin_main.cpp:6916:26: note: in expansion of macro 'LCD_MESSAGEPGM' if (wait_for_heatup) LCD_MESSAGEPGM(MSG_BED_DONE); ^ In file included from sketch\Marlin_main.cpp:223:0: Marlin.h:358: error: expected unqualified-id before 'do' #define KEEPALIVE_STATE(n) do{ busy_state = n; }while(0) ^ sketch\Marlin_main.cpp:6917:5: note: in expansion of macro 'KEEPALIVE_STATE' KEEPALIVE_STATE(IN_HANDLER); ^ Marlin.h:358: error: expected unqualified-id before 'while' #define KEEPALIVE_STATE(n) do{ busy_state = n; }while(0) ^ sketch\Marlin_main.cpp:6917:5: note: in expansion of macro 'KEEPALIVE_STATE' KEEPALIVE_STATE(IN_HANDLER); ^ Marlin_main.cpp:6918: error: expected declaration before '}' token } ^ exit status 1 expected 'while' before 'float'
Re: Enabling #define RGB_LED results in compiler error May 08, 2017 06:57AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Enabling #define RGB_LED results in compiler error May 08, 2017 10:09AM |
Re: Enabling #define RGB_LED results in compiler error May 08, 2017 10:41AM |
Re: Enabling #define RGB_LED results in compiler error May 08, 2017 11:14AM |
Re: Enabling #define RGB_LED results in compiler error May 09, 2017 04:45AM |
Re: Enabling #define RGB_LED results in compiler error May 09, 2017 07:53AM |
#if ENABLED(PRINTER_EVENT_LEDS) // Gradually change LED strip from blue to violet as bed heats up if (!wants_to_cool) { const uint8_t red = map(constrain(temp, start_temp, target_temp), start_temp, target_temp, 0, 255); if (red != old_red) set_led_color((old_red = red), 0, 255); } } #endif
#if ENABLED(PRINTER_EVENT_LEDS) // Gradually change LED strip from blue to violet as bed heats up if (!wants_to_cool) { const uint8_t red = map(constrain(temp, start_temp, target_temp), start_temp, target_temp, 0, 255); if (red != old_red) set_led_color((old_red = red), 0, 255); } #endif
Re: Enabling #define RGB_LED results in compiler error May 09, 2017 10:35AM |
Re: Enabling #define RGB_LED results in compiler error May 09, 2017 12:08PM |
Re: Enabling #define RGB_LED results in compiler error May 09, 2017 06:29PM |
Dust
Good spotting...
I've updated the github issue with these details. One day ill learn how to submit the fix to the real code...
Re: Enabling #define RGB_LED results in compiler error May 10, 2017 05:34PM |
AlpinaV8
*unhelpful remark removed* I recommend Visual Studio with the Visual Micro plugin.Quote
Dust
Good spotting...
*Admin note: rude, unhelpful comments will be removed.
