Jes
Marlin configurator
May 17, 2017 03:59AM
Introduce new version of Marlin configurator
installation:
sudo npm -g i marlin-conf
then right click in Marlin folder with git repository and choose Open in Terminal
and type
mct
updated version with ability to load users' old configurations - try out in an empty folder then choose desired release and drag Configuration.h in browser
full documentation
documentation used from https://github.com/MarlinFirmware/MarlinDocumentation]MarlinDocumentation[/url]
Re: Marlin configurator
May 17, 2017 12:50PM
This tool should allow you to migrate a very old Configuration.h files to the current code base.
If you have a printer with a very old version of Marlin, this should make it much easier to move your settings over to the current version of Marlin.
Jes
May 26, 2017 06:46AM
added a lot of features:
  • show help for G-codes
  • show allowed options/gcodes depends your configuration
  • compiling and uploading firmware via PlatformIO
  • access to all serial ports using console manager (Linux/Mac with auto ports changing detection)
  • quick navigate with a right sided navigation bar
May 28, 2017 03:51AM
This looks fantastic. Is there anyway you cam make it auto run in windows 7?
I did install what you said but I couldn't get it working. Yes I'm that thick smiling smiley
Jes
May 28, 2017 05:53AM
deuse
Check out this Windows Installation
if you have troubles - just inform at which step it occurs
i tried it under Win2003
Jes
May 29, 2017 04:56PM
June 03, 2017 10:20AM
tried all of that and it doesn't work
Jes
June 03, 2017 01:52PM
reworked toolbar and works console under windows 2.6.3
Jes
June 21, 2017 06:47AM
new features added for npm package 2.6.6
- ability to use base files from Examples
- simple helper to manipulate printer's head from console
Jes
July 15, 2017 03:49AM
released new version 2.7.8
fixed: console 3d Command menu
added:
- external upnp access
- ability to use phone as web cam
- simultaneously working
- store current config
- upload stored config
Jes
November 09, 2017 08:27AM
new version 2.8.0 with ability to publicate your configuration [github.com]
and list of published [lt.rv.ua] with comment and sharings ability
