Preserve UBL Mesh Between Firmware Updates July 02, 2017 03:25AM |
Re: Preserve UBL Mesh Between Firmware Updates July 02, 2017 10:30AM |
Re: Preserve UBL Mesh Between Firmware Updates July 02, 2017 04:52PM |
Re: Preserve UBL Mesh Between Firmware Updates July 02, 2017 11:06PM |
You are welcome.Quote
brucehvn
Thanks Roxy. This will be very helpful.
Yes. But no minus sign on the 0 Do a G29 S0Quote
brucehvn
So when I usually save my mesh, I do a G29 S which then says it is saving to mesh 0. So I assume the commands you listed above would be G29 L0 T and G29 S-0?
Oh! Read the documentation. Fade Height is a very powerful concept. With the Mesh Bed Leveling schemes, you can set the distance to eleminate any correction. The default for UBL is 10.0 mm. You set it with G29 F 10.0Quote
brucehvn
What is the fade height and where is it set?
The mesh data is preserved. (Assuming you don't change the mesh dimenstions.) It will be there. It is saved in the free space at the end of the EEPROM.Quote
brucehvn
If I do a M502/M500 to pull in some changed values from the configuration.h, would that wipe out the mesh, or is it still preserved?
Re: Preserve UBL Mesh Between Firmware Updates July 02, 2017 11:26PM |
Re: Preserve UBL Mesh Between Firmware Updates July 03, 2017 12:45AM |
I did not say to do a G29 S-0.Quote
Roxy
But... there is a fall back position too. You can save your mesh data to your host computer by doing a G29 S-1
