Manual Mesh Bed Leveling no z endstop
Posted by omgalof
July 03, 2017 11:19AM
hi, is it not possible to do a Manual Mesh Bed Leveling whiteout having a end-stop for the Z axis? because in my tries the extruder did smash in to the bad '-'
Re: Manual Mesh Bed Leveling no z endstop
September 26, 2017 12:33PM
Any new findings about this topic? This topic is on my table now while fine tuning my i3 Rework.
September 26, 2017 01:23PM
I am curious on this...
no Z-endstop??
are you saying there is no switch to tell the system when the Z movement has reached its limit?
IF so, ya I see no way to do it.... How could the system know where the build plate was so it has a point of reference?
September 26, 2017 02:21PM
To me, it was contradictory to have a Z endstop and to do Manual (Mesh) Bed Leveling, but this guide speaks of a metal arm (seek for those two words on that page) and THAT little travel distance of the metal arm is the +/- area of adjustment, so in the end it worked for me. I think I will replace that with an opto endstop, that will allow me better adjustment, I think. So that's my experience so far with this. And true, @JustSumGuy, how in the world would Marlin have an opportunity to sense the bed without an Endstop?
Other idea: Would manual bed leveling also work by placing the Z axis' only endstop on the high end of the Z axis and then go negative from there in order to find the bed at a defined distance?
                 +<-- Endstop
Bed -------------Z^
September 26, 2017 05:39PM
RepMike
                 +<-- Endstop
Bed -------------Z^
I would avoid that, in case of a skipped step or some other malfunction you could drive your head into the bed sad smiley
IMHO endstop with head close to bed.....
makes me wonder tho... when in operation after homeing does marlin pay any attention to the endstop?
September 26, 2017 07:53PM
JustSumGuy
Practically every 3D printer runs on the assumption that it won't skip steps. Once printing starts, the endstops aren't checked again. So if you can't assume that every step will work correctly, you can't reliably print at all. In which case, it doesn't matter if the endstop is at the top or bottom. Typically, Delta printers have endstops at the top of each tower (plus perhaps a bed-detection probe).
Mesh bed leveling really isn't "manual"... it uses the Z end-stop (which must be triggered when the nozzle touches the bed) to probe the bed around a grid. If you use the G29 command without a probe, the nozzle will crash into the bed.
You *can* print without using a Z endstop. The printer assumes that at power-on, it is at Z=0. So use a piece of paper to set the Z height, then turn the printer on and you're good to go. But if you use Z homing (X & Y are OK) or bed levelling, the nozzle will crash into the bed.
What I do is to have the Z endstop always on. This way, an accidental home won't crash into the bed. When I want to set the Z height, I do a Z home, then manually wind the head down to grip a piece of paper.
September 27, 2017 11:15AM
frankvdh
JustSumGuy
So many ways to do it I guess smiling smiley I thought "Manual mesh" was what I do. I activate this via my LCD control panel. The system homes ALL first, then I click the knob and it starts by going to the first of nine points where I use a bit of paper and adjust via the knob by .025 (I think) up or down until I get the grip I want on the paper, then when all nine points are complete I save the mesh to eeprom.
I do this with the bed at 70c and the tip clean and at 170c this usually works well for a month or so then I have to redo it. I ordered a BLTouch the other day, see if I can fit that in the head setup.....
I am surprised the Z-Endstop does not act as a bed protector..... I have a buddy that drove his head into his Prusa i3 bed and was not around, it burned and ground the head into a hole right thru the heating traces after a few hours....
