Hi any help would be appreciated
I am presently running a 3d sprinter setup. I can connect sanguinololu with Pronterface and run 3d Printer on my computer. So hardware/computer connection is OK. I wanted to add graphic display to my printer so I wanted to upgrade to Marlin but Im having a tough time getting it to upload. I upgraded my IDE to current version and I'm having a hell of a time uploading file to sanguinololu board. Ive checked everything i can think of
Board: "sanguino"
Processor: ATmega1284 or ATmega1284P (16Mhz)
Port: Com3
Programmer: AVR ISP
When I select board info
BN: unknown board
VID: 0403
PID: 6001
SN: Upload any sketch to obtain it
When I select Serial Monitor. I get this in the window so it is talking to the board
Sprinter
1.3.11T / 19.03.2012
start
SD Start
SD init fail
Soft PWM Init
Planner Init
Stepper Timer init
Free Ram: 12734
Plan Buffer Size:1152 / 16
Every time I try to compile and upload I get this message
Arduino: 1.8.3 (Windows 10), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
Sketch uses 106528 bytes (81%) of program storage space. Maximum is 130048 bytes.
Global variables use 4611 bytes (28%) of dynamic memory, leaving 11773 bytes for local variables. Maximum is 16384 bytes.
E:\Arduino\hardware\tools\avr/bin/avrdude -CE:\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\D\AppData\Local\Temp\arduino_build_101790/Marlin_sanguinolu.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, [
www.bdmicro.com]
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x53
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x69
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x69
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
avrdude done. Thank you.
An error occurred while uploading the sketch
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Ive spent about 10 hour on this problem to no solution. Any suggestion would be appreciated
dschiri1
