TMC2130 spreadCycle configuration July 30, 2017 03:48AM |
Re: TMC2130 spreadCycle configuration August 04, 2017 03:00PM |
Re: TMC2130 spreadCycle configuration August 04, 2017 03:02PM |
#define HAVE_TMC2130
#if ENABLED(HAVE_TMC2130)
// CHOOSE YOUR MOTORS HERE, THIS IS MANDATORY
#define X_IS_TMC2130
//#define X2_IS_TMC2130
#define Y_IS_TMC2130
//#define Y2_IS_TMC2130
//#define Z_IS_TMC2130
//#define Z2_IS_TMC2130
//#define E0_IS_TMC2130
//#define E1_IS_TMC2130
//#define E2_IS_TMC2130
//#define E3_IS_TMC2130
//#define E4_IS_TMC2130
* Stepper driver settings
#define R_SENSE 0.11 // R_sense resistor for SilentStepStick2130
#define HOLD_MULTIPLIER 0.5 // Scales down the holding current from run current
#define INTERPOLATE 1 // Interpolate X/Y/Z_MICROSTEPS to 256
#define X_CURRENT 636 // rms current in mA. Multiply by 1.41 for peak current.
#define X_MICROSTEPS 32 // 0..256
#define Y_CURRENT 636
#define Y_MICROSTEPS 32
#define Z_CURRENT 1000
#define Z_MICROSTEPS 16
//#define X2_CURRENT 1000
//#define X2_MICROSTEPS 16
//#define Y2_CURRENT 1000
//#define Y2_MICROSTEPS 16
//#define Z2_CURRENT 1000
//#define Z2_MICROSTEPS 16
//#define E0_CURRENT 1000
//#define E0_MICROSTEPS 16
//#define E1_CURRENT 1000
//#define E1_MICROSTEPS 16
//#define E2_CURRENT 1000
//#define E2_MICROSTEPS 16
//#define E3_CURRENT 1000
//#define E3_MICROSTEPS 16
//#define E4_CURRENT 1000
//#define E4_MICROSTEPS 16
* Use Trinamic's ultra quiet stepping mode.
* When disabled, Marlin will use spreadCycle stepping mode.
//#define STEALTHCHOP
* Let Marlin automatically control stepper current.
* This is still an experimental feature.
* Increase current every 5s by CURRENT_STEP until stepper temperature prewarn gets triggered,
* then decrease current by CURRENT_STEP until temperature prewarn is cleared.
* Adjusting starts from X/Y/Z/E_CURRENT but will not increase over AUTO_ADJUST_MAX
* Relevant g-codes:
* M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given.
* M906 S1 - Start adjusting current
* M906 S0 - Stop adjusting current
* M911 - Report stepper driver overtemperature pre-warn condition.
* M912 - Clear stepper driver overtemperature pre-warn condition flag.
//#define AUTOMATIC_CURRENT_CONTROL
#if ENABLED(AUTOMATIC_CURRENT_CONTROL)
#define CURRENT_STEP 50 // [mA]
#define AUTO_ADJUST_MAX 636 // [mA], 1300mA_rms = 1840mA_peak
#define REPORT_CURRENT_CHANGE
#endif
* The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD.
* This mode allows for faster movements at the expense of higher noise levels.
* STEALTHCHOP needs to be enabled.
* M913 X/Y/Z/E to live tune the setting
//#define HYBRID_THRESHOLD
#define X_HYBRID_THRESHOLD 80 // [mm/s]
#define X2_HYBRID_THRESHOLD 100
#define Y_HYBRID_THRESHOLD 80
#define Y2_HYBRID_THRESHOLD 100
#define Z_HYBRID_THRESHOLD 4
#define Z2_HYBRID_THRESHOLD 4
#define E0_HYBRID_THRESHOLD 30
#define E1_HYBRID_THRESHOLD 30
#define E2_HYBRID_THRESHOLD 30
#define E3_HYBRID_THRESHOLD 30
#define E4_HYBRID_THRESHOLD 30
* Use stallGuard2 to sense an obstacle and trigger an endstop.
* You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin.
* If used along with STEALTHCHOP, the movement will be louder when homing. This is normal.
* X/Y_HOMING_SENSITIVITY is used for tuning the trigger sensitivity.
* Higher values make the system LESS sensitive.
* Lower value make the system MORE sensitive.
* Too low values can lead to false positives, while too high values will collide the axis without triggering.
* It is advised to set X/Y_HOME_BUMP_MM to 0.
* M914 X/Y to live tune the setting
#define SENSORLESS_HOMING
#if ENABLED(SENSORLESS_HOMING)
#define X_HOMING_SENSITIVITY 19
#define Y_HOMING_SENSITIVITY 19
#endif
* You can set your own advanced settings by filling in predefined functions.
* A list of available functions can be found on the library github page
* [github.com]
* Example:
* #define TMC2130_ADV() { \
* stepperX.diag0_temp_prewarn(1); \
* stepperX.interpolate(0); \
/*#define TMC2130_ADV() { \
stepperX.external_ref(1); \
stepperY.external_ref(1); \
stepperX.blank_time(24);\
stepperY.blank_time(24);\
stepperX.off_time(2);\
stepperY.off_time(2);\
stepperX.hysterisis_start(0);\
stepperY.hysterisis_start(0);\
stepperX.hysterisis_low(13); \
stepperY.hysterisis_low(13); \
stepperX.run_current(31);\
stepperY.run_current(31);\
stepperX.hold_current(12);\
stepperY.hold_current(12);\
stepperX.power_down_delay(2); \
stepperY.power_down_delay(2); \
stepperX.coolstep_min_speed(300);\
stepperY.coolstep_min_speed(300);\
stepperX.sg_min(4);\
stepperY.sg_min(4);\
stepperX.sg_max(10);\
stepperY.sg_max(10);\
stepperX.smart_min_current(1);\
stepperY.smart_min_current(1);\
stepperX.sg_step_width(8);\
stepperY.sg_step_width(8);\
stepperX.sg_current_decrease(32);\
stepperY.sg_current_decrease(32);\
Re: TMC2130 spreadCycle configuration August 04, 2017 06:13PM |
Re: TMC2130 spreadCycle configuration August 04, 2017 11:47PM |
butchja
I increased my motors supply voltage by a cheap ebay step up converter from 12V to 26V. To do so I cutted motor supply pin to my ramps and fed it directly from above by wire. I have removed my diode protector boards because they have reference to my ramp's 12V.
Re: TMC2130 spreadCycle configuration August 05, 2017 04:30AM |
Re: TMC2130 spreadCycle configuration August 05, 2017 03:23PM |
Re: TMC2130 spreadCycle configuration August 05, 2017 04:32PM |
Re: TMC2130 spreadCycle configuration August 05, 2017 04:49PM |
Re: TMC2130 spreadCycle configuration August 06, 2017 04:24AM |
Re: TMC2130 spreadCycle configuration August 06, 2017 04:40AM |
Re: TMC2130 spreadCycle configuration August 06, 2017 04:44AM |
Re: TMC2130 spreadCycle configuration August 06, 2017 05:28AM |
C:\Users\x\AppData\Local\Temp\arduino_build_245800\sketch\serial.cpp: In function 'void serial_spaces(uint8_t)':
serial.cpp:36: error: 'PROPORTIONAL_FONT_RATIO' was not declared in this scope
void serial_spaces(uint8_t count) { count *= (PROPORTIONAL_FONT_RATIO); while (count--) MYSERIAL.write(' '); }
C:\Users\x\AppData\Local\Temp\arduino_build_245800\sketch\stepper.cpp: In static member function 'static void Stepper::init()':
stepper.cpp:1021: error: 'TMC_ADV' was not declared in this scope
TMC_ADV()
Re: TMC2130 spreadCycle configuration August 06, 2017 05:43AM |
Re: TMC2130 spreadCycle configuration August 06, 2017 11:08AM |
Re: TMC2130 spreadCycle configuration August 07, 2017 02:55PM |
Re: TMC2130 spreadCycle configuration August 07, 2017 04:27PM |
Re: TMC2130 spreadCycle configuration August 07, 2017 05:31PM |
Re: TMC2130 spreadCycle configuration August 08, 2017 06:25AM |
Re: TMC2130 spreadCycle configuration August 13, 2017 06:46AM |
So not every user has to dig into Trianmic's configuration application notes. Since there are stepper motors with a very wide range of inductance there will be no allround configuration, I think. What do you think, is it possible to ask a Trinamic application engineer for some help? I mean official support for TMC2130 is great marketing for them.
Re: TMC2130 spreadCycle configuration August 13, 2017 10:07AM |
Re: TMC2130 spreadCycle configuration August 15, 2017 11:44AM |
Re: TMC2130 spreadCycle configuration August 15, 2017 01:08PM |
Re: TMC2130 spreadCycle configuration August 15, 2017 04:49PM |
Re: TMC2130 spreadCycle configuration May 03, 2018 07:18AM |
'stepperX' does not name a typeI get the same messages for stepperY and stepperZ. I also tried the default example mentioned in the Marlin code:
/ * Example: */
#define TMC_ADV() { \
stepperY.interpolate(0); \
The same error appers with this code as well. Do I have to define or include something else to use this stepper-types? And is there some kind of guide line how to configure the drivers the right way, or do I simply try things out?|
Re: TMC2130 spreadCycle configuration May 03, 2018 10:08AM |
TMC_ADV () { \
I added them and removed all empty lines. hysteresis_start also needs to be changed to hstrt(..) and hysteresis_low to hend(..). Now compiling works without an error.
