Marlin change tool bug
August 16, 2017 03:16PM
I control my printer using Marlin firmware.
I have a dual extruder printer if i print using the first extruder (T0) is all right but if i change extruder using gcode (T1) the machine lose position and go crazy(random).
I suppose that the problem is in the gcode_T() function but i don't know where .
Someone who are using this firmware can give me a help?
Thanks
Re: Marlin change tool bug
August 17, 2017 04:16AM
I noted that the Y AXIS don't move and only X axis go left hitting the endstop(I stopped the macchine using Emergystop).
And if i change tool and i do normal movements (XYZ) is all right but if i call G92 E0 the problem start.
Edited 1 time(s). Last edit at 08/17/2017 05:19AM by DapDeveloper.
August 17, 2017 05:54AM
are you using dual steppers on your Y axis? Or dual steppers on Z?
Ie trying to use e1 for two things
How about posting your config and some machine details as I suspect its user error, but cant attempt to replicate without your config.
no one else has reported any dual extruder issues...
Edited 1 time(s). Last edit at 08/17/2017 05:59AM by Dust.
August 17, 2017 10:49AM
thanks for the answer.
I have a printer with 2 extruder on X axis.
The problem is when the function gcode_G92() call the function sync_plan_position_e(), i tried to remove this call and work.
