M218 Z-Offset without DualCarriage or SwitchingExtruder August 29, 2017 03:09AM |
#if EXTRUDERS > 1
case 218: // M218 - set hotend offset (in mm), T X Y
if(setTargetedHotend(218)){
break;
if(code_seen('X'))
extruder_offset[X_AXIS][tmp_extruder] = code_value();
if(code_seen('Y'))
extruder_offset[Y_AXIS][tmp_extruder] = code_value();
#ifdef DUAL_X_CARRIAGE
if(code_seen('Z'))
extruder_offset[Z_AXIS][tmp_extruder] = code_value();
#endif
SERIAL_ECHO_START;
SERIAL_ECHOPGM(MSG_HOTEND_OFFSET);
for(tmp_extruder = 0; tmp_extruder < EXTRUDERS; tmp_extruder++)
SERIAL_ECHO(" ");
SERIAL_ECHO(extruder_offset[X_AXIS][tmp_extruder]);
SERIAL_ECHO(",");
SERIAL_ECHO(extruder_offset[Y_AXIS][tmp_extruder]);
SERIAL_ECHO(",");
SERIAL_ECHO(extruder_offset[Z_AXIS][tmp_extruder]);
#endif
SERIAL_ECHOLN("");
}break;
#endif
Re: M218 Z-Offset without DualCarriage or SwitchingExtruder August 29, 2017 05:10AM |
current_position[Z_AXIS] -= hotend_offset[Z_AXIS][active_extruder] - hotend_offset[Z_AXIS][tmp_extruder];This is located in a "#if ENABLED(DUAL_X_CARRIAGE)" section by default. You can post the line right before this section. A z-offset now makes the z_axis move when sending T1/T0.
