Marlin 1.1.5 September 09, 2017 03:00PM |
Re: Marlin 1.1.5 September 09, 2017 03:01PM |
Re: Marlin 1.1.5 September 10, 2017 02:15PM |
Re: Marlin 1.1.5 September 11, 2017 03:44PM |
Re: Marlin 1.1.5 September 11, 2017 05:14PM |
Roxy
Did you do a M502 followed by a M500 ?
Re: Marlin 1.1.5 September 11, 2017 07:34PM |
Roxy
Re: Marlin 1.1.5 September 12, 2017 06:28PM |
Re: Marlin 1.1.5 September 12, 2017 07:32PM |
JustSumGuy
Marlin-RC8BF-HICi3
Is this a modified flavor of Marlin 1.1.5 for a specific printer ?
Re: Marlin 1.1.5 September 14, 2017 02:20PM |
Re: Marlin 1.1.5 September 14, 2017 04:19PM |
JustSumGuy
sounds like the controller then.
Re: Marlin 1.1.5 September 14, 2017 07:08PM |
Re: Marlin 1.1.5 September 14, 2017 09:00PM |
Re: Marlin 1.1.5 September 15, 2017 02:16PM |
Roberts_Clif
JustSumGuy
I thought is was the controller also so I replaced with my backup controllers, to which I have one for each 3D Printer.
If it is bad then I have 4 bad Controllers, all with the same errors.
All working with Marlin-RC8BF-HICi3.zip. and like I said they work in Marlin 1.1.5 they just display the " Endstops Z " or "G28 Z Forbidden" and CRC memory error on M500.
You know it's crazy I am still on Marlin 1.1.X with Marlin-RC8BF-HICi3.zip will be trying Marlin 1.1.1 thru 1.1.3 till I find where it starts erring. I know Marlin 1.1.4 and above errors.
Compiled Marlin 1.1.1 displays " Endstops Z " error however no CRC memory error will step tomorrow to Marlin 1.1.2 to duplicate memory error.
Re: Marlin 1.1.5 September 16, 2017 12:01PM |
Re: Marlin 1.1.5 September 16, 2017 12:22PM |
Roberts_Clif
All functions work perfectly only displaying " Endstops Z " or sometimes " G28 Z Forbidden " thou still Prints a perfect 3D Model.
M500 " CRC memory errors ???? " are scary because don't know what the 3D Printer will do with CRC Errors.
Asking for Help - What can I do to fix this.
Re: Marlin 1.1.5 September 16, 2017 01:25PM |
Re: Marlin 1.1.5 September 16, 2017 08:25PM |
Roberts_Clif
Yes exactly where I got the errors, doing M502, M500 several time even thinking the error would go away.
I was doing The M500 when the error occurred.
I guess I stated this way back in Marlin1.1.4 topic When Marlin 1.1.5 came out upgraded to Marlin 1.1.5 and dropped the Marlin 1.1.4 Topic and started this topic.
Re: Marlin 1.1.5 September 16, 2017 11:15PM |
Roxy
OK! That definitely should not happen! v2.0.0 is going to be showing up soon. When it does, I'll be bringing it up on several printers. I will be doing M502's and M500's to initialize the EEPROM.
I'll watch and make sure that error doesn't show up. But I don't find the error message about the CRC you are seeing. I see this error message:
else {
#if ENABLED(EEPROM_CHITCHAT)
SERIAL_ERROR_START();
SERIAL_ERRORPGM("EEPROM CRC mismatch - (stored) ");
SERIAL_ERROR(stored_crc);
SERIAL_ERRORPGM(" != ");
SERIAL_ERROR(working_crc);
SERIAL_ERRORLNPGM(" (calculated)!");
#endif
Re: Marlin 1.1.5 October 16, 2017 10:10AM |
Roberts_Clif
Marlin 1.1.5 after Auto home while displaying CUSTOM_MACHINE_NAME Z-axis will rise changing the display to " Endstops Z " or "G28 Z Forbidden"
Re: Marlin 1.1.5 August 27, 2018 08:01AM |
