Print gaps. Marlin settings, slicer settings or mechanical? October 05, 2017 12:35PM |
Re: Print gaps. Marlin settings, slicer settings or mechanical? October 05, 2017 01:02PM |
Re: Print gaps. Marlin settings, slicer settings or mechanical? October 05, 2017 02:49PM |
Re: Print gaps. Marlin settings, slicer settings or mechanical? October 05, 2017 06:09PM |
drmacro
The bed temp for that print was 110, hot end 230.
Not sure how I'd calibrate the extrusion. (I assume you mean the amount of filament being pushed through the nozzle.)
I only have a cooling fan on the the hot end (i.e. on the cooling fins above the heat break)
I did double check the setting in Slic3r for the nozzle diameter before I created the gcode.
I'm guessing the x and y are close to calibrated since it is a 20mm cube and the the x/y dimensions are 20x20.1. The z is 19.85.
When you say 'elephant foot', do you refer to the brim or the deformation in the mid layers? I have used the brim, almost from day one, since the abs slurry never seemed to be enough to get good adhesion.
I would also note, at one point this printer worked well. And then started giving me grief...of course I can't pin point a time or what changed.
