where is Z max? October 09, 2017 05:05PM |
M43 P16 W Watching pins PIN: 16 Port: C0 SCL PIN: 16 Port: C0 SCL
M119*31 Reporting endstop status x_min: open y_min: open z_probe: open
configuration.h //=========================================================================== //============================== Endstop Settings =========================== //=========================================================================== // @section homing // Specify here all the endstop connectors that are connected to any endstop or probe. // Almost all printers will be using one per axis. Probes will use one or more of the // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG #define USE_ZMAX_PLUG
pins_sanguinololu_12.h // // Limit Switches // #define X_STOP_PIN 18 #define Y_STOP_PIN 19 #define Z_STOP_PIN 20 // my own code #define X_MIN_PIN 18 #define Y_MIN_PIN 19 #define Z_MAX_PIN 16 #ifndef Z_MIN_PROBE_PIN #define Z_MIN_PROBE_PIN 20 #endif //endof my own code
M43 PIN: 15 Port: D7 X_STEP_PIN protected PIN: 16 Port: C0 SCL Input = 0 PIN: 17 Port: C1 SDA Input = 0 PIN: 18 Port: C2 X_MIN_PIN protected . X_STOP_PIN protected PIN: 19 Port: C3 Y_MIN_PIN protected . Y_STOP_PIN protected PIN: 20 Port: C4 Z_MAX_PIN protected . Z_MIN_PROBE_PIN protected . Z_STOP_PIN protected
Solved October 09, 2017 05:36PM |
Re: where is Z max? October 18, 2017 02:21AM |
#ifdef Z_STOP_PIN
#if Z_HOME_DIR < 0
#define Z_MIN_PIN Z_STOP_PIN
#define Z_MAX_PIN -1
#else
#define Z_MIN_PIN -1
#define Z_MAX_PIN Z_STOP_PIN
#endif
#endif
