How to use AutoBedLeveling for CNC stock surface mapping ? November 08, 2017 03:34AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 05:29AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 09:44AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 10:14AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 10:21AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 10:31AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 11:04AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 01, 2017 12:19PM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 03, 2017 05:25AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 05, 2017 02:38AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 05, 2017 05:36AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 05, 2017 08:27AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 05, 2017 09:41AM |
UnLtdSoul
Your using a -15.7mm Probe Z offset, which I assume is the offset using an installed bit, but, won't that change when you change out your bit? So, you would have to know what that offset is of the changed bit??? and change it, right?
Unless you are mounting the switch bracket directly to the bit? and the sw is set at 15.7mm below the tip of the bit, no matter what length of the bit is?
But, if you wind up needing to remeasure and reset the Z Probe offset after you change out a bit, then you should consider adding wiring for a touch-plate and use the G30 command. It uses the same Z-min inputs, i have the touch-plate wires and the Z probe limit sw wires in parallel, they both trigger the same Z-min input.
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 05, 2017 06:04PM |
UnLtdSoul
Well, i started to look at your mod's, and i see that we are taking 2 totally different approaches. If what you have is currently working, but, you mainly want to keep the mapping from getting disabled, it is being disabled in the G28 processing, try bypassing line 3743 in Marlin_main with you ck for the Milling define. That should keep the mapping from getting disabled.
That's just what I want to do (G30)Quote
UnLtdSoul
I also think the mods i made should work for you as well, if you don't need or use G30 it will still work.
UnLtdSoul
UnLtdSoul
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 05, 2017 08:38PM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 06, 2017 07:00AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 06, 2017 07:03AM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 06, 2017 05:39PM |
Re: How to use AutoBedLeveling for CNC stock surface mapping ? December 07, 2017 05:18AM |
