Hey folks, I'm hoping you can help.
Currently I'm putting together a laser cutter using Openbuilds ACRO system, running Ramps 1.4 and Marlin. My problem is this.
I need to run 2 Y-axis stepper motors (1.68a), but obviously there's only space for 1 to be connected (I tried wiring in series and parallel but get stutter movement, and yeah did check the drivers).
What I'd like to do is put one of the motors on the Y pins, and the other on E1 or E0. Or since I don't have a need for Z, use the dual Z pins.
Can someone show me the code I need to edit to make this happen? Any help would be greatly appreciated.
