zprobe loses autolevel
Posted by ProSoft
December 01, 2017 04:44AM
I'm using Marlin on my CNC. FIX_MOUNTED_PROBE, Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN. I make the autolevel every time, over the stock, before starting to machine. Everything works correctly. The problem is that when I need to change the tool, I like to do a zprobe after the change, but if I do that, the machine loses its autolevel and starts machining always at the same level.
Re: zprobe loses autolevel
December 01, 2017 12:10PM
homeing Z after doing a autolevel will erase the auto level data
December 01, 2017 12:14PM
Z probe acts the same as homming? Do you know where in the code data is erased
December 01, 2017 12:25PM
The auto level data is stored in the eeprom.
To clarify my previous statement,
If you do a
G29 ; probe bed level
G28 ; home all axis
G29 will perform the bed levelling ans store the results in the eeprom
G28 will home Z and this will reset the bed levelling data
so use
G29
G28 X0 Y0 ;home X Y
G1 Z0 F5000 ; move Z to 0
December 01, 2017 12:45PM
I want a G30 after a tool change, without loosing bed level data (MILLING CNC)
